Page 1 of 2
Android Z-Way 0.2.8 can't connect to v2.0.1-rc4
Posted: 17 Dec 2014 14:53
by LAN-Opfer
...but I see a warning in the Dashboard:
Warning:
[DEBUG] Status report requested
Type: debug
Timestamp: 17/12/14-12:47
Re: Android Z-Way 0.2.8 can't connect to v2.0.1-rc4
Posted: 19 Dec 2014 18:44
Can you provide log from server? Few lines from connection process. We will also update the app in a few days as it was released pretty buggy this time
Posted: 19 Dec 2014 19:15
by LAN-Opfer
I tried it at 17:08
  • [2014-12-19 17:07:55.061] [D] [zway] SENT ACK
    [2014-12-19 17:07:55.062] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
    [2014-12-19 17:07:55.062] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.val = 0.000000
    [2014-12-19 17:07:55.062] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
    [2014-12-19 17:07:55.063] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
    [2014-12-19 17:07:55.063] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2 = Empty
    [2014-12-19 17:08:28.394] [D] [zway] RECEIVED: ( 01 0E 00 04 00 03 08 32 02 21 12 00 00 00 00 FD )
    [2014-12-19 17:08:28.394] [D] [zway] SENT ACK
    [2014-12-19 17:08:28.394] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
    [2014-12-19 17:08:28.395] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.val = 0.000000
    [2014-12-19 17:08:28.395] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
    [2014-12-19 17:08:28.396] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
    [2014-12-19 17:08:28.396] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2 = Empty
    [2014-12-19 17:08:45.378] [core] Notification: debug (debug): Status report requested
    [2014-12-19 17:09:01.727] [D] [zway] RECEIVED: ( 01 0E 00 04 00 03 08 32 02 21 12 00 00 00 00 FD )
    [2014-12-19 17:09:01.727] [D] [zway] SENT ACK
    [2014-12-19 17:09:01.727] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
    [2014-12-19 17:09:01.728] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.val = 0.000000
    [2014-12-19 17:09:01.728] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
    [2014-12-19 17:09:01.728] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
    [2014-12-19 17:09:01.729] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2 = Empty
    [2014-12-19 17:09:08.481] [D] [zway] RECEIVED: ( 01 08 00 04 00 05 02 84 07 77 )
    [2014-12-19 17:09:08.481] [D] [zway] SENT ACK
    [2014-12-19 17:09:08.481] [D] [zway] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
    [2014-12-19 17:09:08.482] [zway] Node 5:0 CC Wakeup: Wakeup notification
    [2014-12-19 17:09:08.482] [D] [zway] SETDATA devices.5.instances.0.commandClasses.132.data.lastWakeup = 1419005348 (0x54944da4)
    [2014-12-19 17:09:08.482] [D] [zway] SETDATA devices.5.data.isAwake = True
    [2014-12-19 17:09:08.482] [D] [zway] SETDATA devices.5.data.lastSend = 44276 (0x0000acf4)
    [2014-12-19 17:09:08.482] [D] [zway] SETDATA devices.5.data.lastNonceGet = 43276 (0x0000a90c)
    [2014-12-19 17:09:08.482] [D] [zway] Running wakeup handler for node 5
I have also send a Report from my Smartphone - the App crashed
Uwe
Posted: 25 Dec 2014 02:43
It has been updated. Did it helped?
Posted: 25 Dec 2014 23:45
by LAN-Opfer
...not really :-(
The app does not Crash any more - but I got an error: "Can't connect"
  • [2014-12-25 21:36:50.633] [D] [zway] Job 0x13: deleted from queue
    [2014-12-25 21:37:16.818] [D] [zway] RECEIVED: ( 01 0E 00 04 00 03 08 32 02 21 12 00 00 00 00 FD )
    [2014-12-25 21:37:16.819] [D] [zway] SENT ACK
    [2014-12-25 21:37:16.819] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
    [2014-12-25 21:37:16.819] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.val = 0.000000
    [2014-12-25 21:37:16.820] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
    [2014-12-25 21:37:16.820] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
    [2014-12-25 21:37:16.820] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2 = Empty
    [2014-12-25 21:37:50.151] [D] [zway] RECEIVED: ( 01 0E 00 04 00 03 08 32 02 21 12 00 00 00 00 FD )
    [2014-12-25 21:37:50.152] [D] [zway] SENT ACK
    [2014-12-25 21:37:50.152] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
    [2014-12-25 21:37:50.152] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.val = 0.000000
    [2014-12-25 21:37:50.153] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
    [2014-12-25 21:37:50.153] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
    [2014-12-25 21:37:50.153] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2 = Empty
    [2014-12-25 21:37:55.604] [core] Notification: debug (debug): Status report requested
    [2014-12-25 21:38:23.485] [D] [zway] RECEIVED: ( 01 0E 00 04 00 03 08 32 02 21 12 00 00 00 00 FD )
    [2014-12-25 21:38:23.485] [D] [zway] SENT ACK
    [2014-12-25 21:38:23.485] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
    [2014-12-25 21:38:23.485] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.val = 0.000000
    [2014-12-25 21:38:23.486] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
    [2014-12-25 21:38:23.486] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
    [2014-12-25 21:38:23.486] [D] [zway] SETDATA devices.3.instances.0.commandClasses.50.data.2 = Empty
    [2014-12-25 21:38:56.818] [D] [zway] RECEIVED: ( 01 0E 00 04 00 03 08 32 02 21 12 00 00 00 00 FD )
    [2014-12-25 21:38:56.818] [D] [zway] SENT ACK
Posted: 29 Dec 2014 21:12
Can you create new profile and make search in local network for the box? Are you sure your phone is in the same Wifi network? Or you are trying to connect via remote access?
Z-Way log will not help... we need tcpdump trace. But this is way more complicated.
Posted: 29 Dec 2014 22:52
by LAN-Opfer
I tried to connect to 192.168.178.46:8083 - but I get the error "Can't connect!"
Posted: 30 Dec 2014 09:37
by LAN-Opfer
PoltoS wrote:Z-Way log will not help... we need tcpdump trace. But this is way more complicated.
...perhaps a special version which creates some debug-informations, will help...
Posted: 31 Dec 2014 04:04
can you connect from browser on the SAME phone? Can you make "tcpdump -w ff -ntl port 8083" and send us "ff" file. If possible, with connection from App and from the browser.
Posted: 31 Dec 2014 14:08
by LAN-Opfer
is it possible without root? I have a new Sony Z1 Compact and do not want to root ist.
Could you explain the steps?
Uwe
