UZB1 Ubuntu - Bad data - communication failed
Posted: 19 Dec 2014 13:49
Just got my ZME_UZB1 yesterday and have been trying to get it to work with ubuntu.
Downloaded http://razberry.z-wave.me/z-way-server/ ... v2.0.0.tgz and extracted it to the folder : /home/user/z-way/z-wave-server
change config.xml -> <log-file>/home/user/z-way/log/z-way-server.log</log-file>
Run
then
The server starts and go to : http://localhost:8083/z-way-ha/ -> Preferences -> Automation -> Z-Wave binding and change Serial port to Z-Wave dongle to : "/dev/ttyACM0"
The output in z-way-server.log is then:
What is wrong?
Run
export LD_LIBRARY_PATH="/home/user/z-way/z-way-server/libs"Code: Select all
./z-way-serverThe output in z-way-server.log is then:
[2014-12-19 11:35:36.782] [D] [zway] Initialization done
[2014-12-19 11:35:36.782] [D] [zway] Job 0x07 (Get controller info and supported function classes): success
[2014-12-19 11:35:36.782] [C] [zway] Device is not compatible. Terminating...
[2014-12-19 11:35:36.782] [zway] Removing job: Get controller info and supported function classes
[2014-12-19 11:35:36.782] [D] [zway] RECEIVED: ( 01 0C 00 0A 05 00 01 02 01 03 21 20 86 7A )
[2014-12-19 11:35:36.782] [D] [zway] SENT ACK
[2014-12-19 11:35:36.782] [W] [zway] No job of class 0x0a is waiting for callback 0x05
[2014-12-19 11:35:36.782] [zway] Unhandled callback for function 0x00
[2014-12-19 11:35:36.782] [zway] Removing job: Unknown function class
[2014-12-19 11:35:36.793] [D] [zway] Worker thread exit point
[2014-12-19 11:35:36.793] [D] [zway] Worker thread successfully finished
[2014-12-19 11:35:36.800] [core] Notification: critical (z-wave): Can not start Z-Wave binding: Error: Bad data - communication failed
[2014-12-19 11:36:12.672] [E] [zway] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
What is wrong?
