Hi all,
I'm trying to enable Sensor values logging in Z-Way HA, but I'm getting the following error messages:
18/12/14 - 17:32Can not init module SensorValueLogging: TypeError: Cannot read property 'get' of undefined
18/12/14 - 7:17Can not init module SensorValueLogging: TypeError: Cannot read property 'get' of undefined
Does anyone have an idea why this is and how to fix it? Thanks!
Re: Can not init module SensorValueLogging
Try doing a force interview looks like its not picked the device up correctly.
Z-Way 2.0.1-RC4 on Raspberry Pi
Forgive my ignorance, but what's a force interview?
Use the new Expert Interface. Goto Configuration, and select the device that may cause the problem.what's a force interview?
At the bottom of that page you select button Force Interview After that you can check result
I may be looking in the wrong place, but I don't see a "Force Interview" button on here:
http://i.imgur.com/pU0o3LS.jpg
That is the old expert gui, but that will work too if you put it in expert mode (lower right corner)
Still can't see it in expert mode: http://i.imgur.com/RfnpawB.jpg
How do I get to the new expert UI?
...click to "advanced Options"
Uwe
Uwe
Z-Way v2.0.1-rc18 on Raspberry Pi
Ah, I just noticed the 2.0.0 update. All is working now, thanks!
