Can not init module SensorValueLogging
RajenK
Post by RajenK »
Hi all,
I'm trying to enable Sensor values logging in Z-Way HA, but I'm getting the following error messages:
18/12/14 - 17:32Can not init module SensorValueLogging: TypeError: Cannot read property 'get' of undefined
18/12/14 - 7:17Can not init module SensorValueLogging: TypeError: Cannot read property 'get' of undefined
Does anyone have an idea why this is and how to fix it? Thanks!
INGY
Re: Can not init module SensorValueLogging
Post by INGY »
Try doing a force interview looks like its not picked the device up correctly.
Z-Way 2.0.1-RC4 on Raspberry Pi
RajenK
Post by RajenK »
Forgive my ignorance, but what's a force interview?
pz1
Post by pz1 »
Use the new Expert Interface. Goto Configuration, and select the device that may cause the problem.
At the bottom of that page you select button Force Interview After that you can check result
RajenK
Post by RajenK »
I may be looking in the wrong place, but I don't see a "Force Interview" button on here:
http://i.imgur.com/pU0o3LS.jpg
pz1
Post by pz1 »
That is the old expert gui, but that will work too if you put it in expert mode (lower right corner)
RajenK
Post by RajenK »
Still can't see it in expert mode: http://i.imgur.com/RfnpawB.jpg
How do I get to the new expert UI?
LAN-Opfer
Post by LAN-Opfer »
...click to "advanced Options"
Uwe
Z-Way v2.0.1-rc18 on Raspberry Pi
RajenK
Post by RajenK »
Ah, I just noticed the 2.0.0 update. All is working now, thanks!
