Problem with changing state from z-wave device via HomeKit
Posted: 31 Dec 2014 17:00
Hey!
like the topic says, i want to update a z-wave device by HomeKit iOS App.
Environment looks like this:
z-Wave Environment:
Controller HW: RPi with Razberry
Controller SW: z-way server (v2.0.1-rc7-7-gff06bfa)
included z-wave device: Fibaro Wall-Plug
(all works fine within this z-wave environment!)
HomeKit Environment:
iPhone6 with iOS8
used App: https://github.com/KhaosT/HomeKit-Demo.git
(successfully paired the HomeKit with RaZberry Controller as a bridge and see the Fibaro Wall-Plug as accessory!)
The Situation:
Using web-GUI "Z-Way Home Automation UI" -> "Widgets" I see the Wall-Plug Switch and when i turn on/off in UI, the HW Wall-Plug will turn on/off correctly.
Using web-GUI "Expert UI" "Control->Switch" I see the Wall-Plug Switch and when i turn on/off in UI, the HW Wall-Plug will turn on/off correctly.
Looking at the iOS "HomeKit-Demo" App on iPhone, while switching on/off (does´t matter which web-GUI is used for switching) i can see, that the accessory characteristic from Wall-Plug is changing (0/1) correctly.
Now, when i switch state of Wall-Plug by HomeKit-Demo-App, the HW-Wall-Plug didn´t turn on/off!
i found, switching the state of "Wall-Plug" in "HomeKit-Demo" App, indeed changes the state of "Wall-Plug" in web-GUI "Z-Way Home Automation UI" too, but NOT in web-GUI "Expert UI"! AND, when i click "update" for "Wall-Plug" switch in "Expert UI" it forces the state from the original unchanged switch state in "Expert UI" back to "Z-Way Home Automation UI" AND "HomeKit-Demo" App.
So, however, it seems that commands from HomeKit will reach the z-way-HA-GUI, but at least not the actual switch-command for device HW in z-way server.
Is this a known issue in z-way, or a problem with the device, or do i need a special module in "Z-Way Home Automation UI" except HomeKitGate for that?
I hope this description is detailed enough for help troubleshooting.
z-Wave Environment:
iPhone6 with iOS8
The Situation:
