tellstick
Varazir
tellstick
Post by Varazir »
Is there a way to combine/add a tellstick to the Razberry and get it to work or do I need a extra software with that ?
pofs
Re: tellstick
Post by pofs »
You need some kind of software that will provide some kind of API to access TellStick. Then you'll be able to call it from Z-Way.
Varazir
Re: tellstick
Post by Varazir »
Mirar
Re: tellstick
Post by Mirar »
I have a tellstick but I haven't tried to connect it to z-way-server HA. What API is needed? (Out of curiosity)
If you connect a tellstick duo to a normal Pi, you need a powered hub. Pi 2 seems (maybe) to be fine without extra power to the tellstick.
Re: tellstick
Mirar wrote:Pi 2 seems (maybe) to be fine without extra power to the tellstick.
Provided that your power supply is up to it.
Mirar
Re: tellstick
Post by Mirar »
Well, yes. I use a 2.1A power supply.
pofs
Re: tellstick
Post by pofs »
Mirar wrote:What API is needed? (Out of curiosity)
No idea :)
Never had that device, and too lazy to google for possible options.
But it should be something that connects with that device over usb/serial interface and provides an ability to send/receive something meaningful via HTTP (so it could be accessed from JS).
Could also be a native module for Z-Way.
Mirar
Re: tellstick
Post by Mirar »
I was thinking what could be needed for a native module. Telldus tellstick duo has a python and a C++ interface already.
Varazir
Re: tellstick
Post by Varazir »
I have problem that the driver for RaZberry isn't loading when I have connected my Tellstick before I power on.
If I connect my tellstick after I have turned on my Pi both works.
The log file say
2015-03-01 16:09:52.983 Error, ERROR: Cannot open serial port /dev/ttyUSB0. Error code 2
2015-03-01 16:09:52.983 Error, ERROR: Failed to open serial port /dev/ttyUSB0
But there are no ttyUSB0 not even when I boot up without the tellstick connected.
I have to add that I use a Raspberry USB hub but I got the same with out using it.
With out the hub my RaspberryPI reboots when I connect the tellstick.
pofs
Re: tellstick
Post by pofs »
There's no any specific driver for RaZberry, it uses a built-in serial port driver.
It must be something to do with your Linux distrib, probably you should upgrade to the latest version.
