set homeId via echo hex > port
Posted: 07 Mar 2015 15:42
by skiv71
Anyone know the format? for the string?
Neil
Re: set homeId via echo hex > port
Posted: 07 Mar 2015 17:52
by pofs
There's no such command, at least the official one. Why?
Posted: 07 Mar 2015 17:57
by skiv71
My attempts to restore a backup and hence homeId and node configs is failing, but if I can set the homeId, I can drop the .xml in and carry on as before :)
Posted: 02 Dec 2015 11:49
by simonchase
I'm facing the same Problem with z-way-server 2.1.1.
I don't wanna remount all my roller shutter switches ( fibaro fgrm-222 ) and my other zwave-components of the wall and re-include them in a new z-wave-network.
Is there any possibility to set the homeID manually ??
In worst case, i've had to recode all my other stuff in z-way-server-ui?!?!
Please help!
Regards Simonchase
(posted also in the German subforum )
Posted: 02 Dec 2015 21:40
Z-Way have backup/restore facilities. HAve you tried this?
