Disappearing devices with ZWay enabled UZB1
Posted: 20 Mar 2015 14:51
by pz1
After command:
sudo /etc/init.d/z-way-server restart
Devices appear to be gone on my Rapberry Pi. After a reboot they do reappear in the new Expert UI, but not in the HA UI. (I only have Dual Fibaro switch and Danfoss Living Connect in this test rig)
In the Expert UI it says that the Device Descriptions are gone. The Fibaro comes back after adding the device description. I am waiting for the LC if it has to be pushed awake.
Edit: Old Expert says interview is complete, New Expert says it is not complete. It looks like old Expert is correct
Re: Disappearing devices with ZWay enabled UZB1
Posted: 24 Mar 2015 00:39
Hm... looks strange. As usually, logs and screenshots of both UIs are needed (interview part - refresh both pages to be really sure they show different results)
Posted: 24 Mar 2015 10:35
by pz1
PoltoS wrote:As usually, logs and screenshots of both UIs are needed
I know
. I did do refreshes of the screen and two reboots. New Expert UI continued to be wrong, and Old blue was correct.
It has not happened since. I could not find anything in the logs at that time.
In retrospect I have the impression that these accidents happened while one of my experimental usermodules crashed on JS error. It did happen with the restart never with a reboot after JS error.
Problem has not reoccurred lately. I'll see if I can force it once more
Posted: 26 Mar 2015 16:03
by pz1
It just happened again after performing twice a z-way-server stop followed by a z-way-server start (around 13:53)
Edit: I had to re-include the Danfoss Lame Connect. It has lost another 12% of battery power
removed zip to save space
Posted: 02 Jul 2015 13:17
by pz1
pz1 wrote:It just happened again after performing twice a z-way-server stop followed by a z-way-server start (around 13:53)
Haven't seen it again, So for the time being I consider this as being rexolved
