Tried to update my Raspi 2 to V2.0.1-RC29 using WEBIF. System still hangs after 30+ minutes. No luck with webbrowser restart. Comes back with the same hanging screen and a since long outdated change log.
Also a second try after cold reboot failed. (same upgrade method to v.2.0 did work).
I do have growing doubts if this will ever lead to a system with more than mediocre reliability.
V2.0.1-RC29
Re: V2.0.1-RC29
After I have installed 28_alpha and I have not updated yet the system is running rock stable. I am sure after I have seen the last developments we will see a reliable system at a certain day. Maybe not tomorrow but maybe at the end of 2015!?
Some optimism is sometime neaded but we also should honor the efforts the guys are doing.
pierre2302
Re: V2.0.1-RC29
My raspberry 1 crashed this night with the version rc28. I installed the RC29 version on raspberry 2, no concern at the moment
pierre2302
Re: V2.0.1-RC29
The crash of my raspberry actually came from a bug of my wifi internet box
Re: V2.0.1-RC29
I've got the same issue with rc29: updating to this version puts one of my raspi cores at 100%, also after a restart. An way to solve this?
RottenMutt
Re: V2.0.1-RC29
thermostat support still doesn't work on RC29, gone is old blue..
i got a smart things hub and am ready to bail! can i use the inclusion process to transfer control over to the smart things hub?
"This starts an inclusion process for a new controller. This new controller will become the new primary controller of your network."
Re: V2.0.1-RC29
Afaik you can't move devices from one controller to an other with Z-Way. In some occasions the stick and devices bound to it may be discovered by other software. OpenRemote used to do that.RottenMutt wrote:can i use the inclusion process to transfer control over to the smart things hub?
I am curious about your experiences with Smartthings
Re: V2.0.1-RC29
Updating to a newer version still does not help: one core at 100% even after a reboot and webinterface does not start.
Has anyone managed to resolve this?
