Hello Everyone,
I just got my RaZberry and installed everything on Raspberry Pi 2.
Unfortunately, when I enter "Expert UI" I see the message:
"Error handling data from server"
I read some posts here that had the same problem(s) but the solution was nowhere to be found.
I tried different Raspberrys, rebooting and re-installing the SD image, but nothing seems to work.
I followed the stpes on the following "Known Problems" guide, but it also didn't work:
http://razberry.z-wave.me/index.php?id=29
There was no mention of ttyAMA0 in the files /etc/inittab and /boot/cmdline.txt.
When I go to "Z-Way Home Automation UI" (right under "Expert UI"), click on "Preferences" then "Automation", I can see "Z-Wave Binding" had been instantiated and configured correctly, as people mentioned in previous posts.
If someone can please give me a direction or an advice on how I should proceed from here that would be great.
Any help will be appreciated.
Thanks in advance.
