1) Logical Rules: List of locks, can't select closed or open, UI says "this field is not optional".
2) scenes: Dimmers i can't turn fully off.
3) why are not locks available in scenes
4) can i change a setting to space out commands? I seem to flood the network when switching large scenes and not all switches activate.
RC-43
RottenMutt
RC-43
Re: RC-43
rc43 should solve your login problem according to recent post on github
https://github.com/Z-Wave-Me/zwave-smar ... -340109812
RottenMutt
Re: RC-43
RC44:
thermostats: i can switch between heat and cool, but if i attempt to change the set temperature the thermostat changes over to heat and the set point doesn't change.
Dimmer Switches: can't be turned off in SENCE
Re: RC-43
Known issue on GithubRottenMutt wrote:1) Logical Rules: List of locks, can't select closed or open, UI says "this field is not optional".
Dont 'know2) scenes: Dimmers i can't turn fully off.
I have asked the same question for switching modes on thermostat devices. I did work around that by writing Z-Wave mode setting commands as JS scripts of type toggleButton. Those can be included in a scene. (Awkward as I needed to write 40 toggleButtons for 10 thermostats)3) why are not locks available in scenes
How many devices do you have in the biggest scene? Cause can also be in a weak network that leads to many retransmissions.4) can i change a setting to space out commands? I seem to flood the network when switching large scenes and not all switches activate.
Alternatively you may consider to split up your scenes in smaller ones and sequence them with module Delayed scene?
Re: RC-43
I am really struggling. I can't log into HA. I have tried rc34, rc37, rc40, rc43. I have edited config.json to have "login"="admin", "password"="admin". In earlier cases I had user not known (something like that), now (rc43) I just get Page - Unable to load data.
When I did have it working last (a week ago), I noticed that the whole system was very slow. Some pages would take a long time to load. The z-wave network controlled by the controller rules was very slow e.g. PIR detect -> turn light on could take 8 seconds.
By the way I am using the new quad core Pi - so I have plenty of processor power. Indeed looking at the cpu usage it rarely gets near 20%, but somehow the whole thing runs very slowly. I have tried disabling some of the rules - no help.
I have tried looking at the log file - but I am not really sure what I am looking at - nothing shows any form of errors anyway.
I have 16 devices.
The Expert UI works fine - there are a couple of devices that don't complete their interview: Fibaro Binary sensor (I have 2), wont complete on AlarmSensor (x2); and Philio-PAN dual switch wont complete on Version. Nothing I can do about these devices - could that be part of the problem?
I would really appreciate some help here. I have been struggling with this for 6 months. In the earlier days rc18 it worked OK (there were always issues). Since I upgraded to the new UI, I completely re-configured my network. And now, I can't log in.
I have 16 devices.
Re: RC-43
Hi timb,
could you please post the profile part of your old config.json?
If you still getting error 'Unable to load data' also a screen shot of the UI and the browsers console would be helpful.
Which modules/apps are running simultaneously on your HA?
I know you've been struggling with latest release candidate versions but maybe an update to new release v.2.0.1 will help.
Btw in v.2.0.1 you could still enter ExpertUI via http://MYRASP:8083/expert after login
Re: RC-43
Hi Ronie
Thanks for responding.
Here's a few facts....
1. the EXPERTUI worked in all versions, albetit a little unresponsive.
2. I had edited the password in config.json to be "admin" - but it already was "admin" - still, I saved it just in case
3. I upgraded to v.2.0.1, I could not get that past the login screen no matter what I did. This time it said "The page at ip:8083 says: User not found. Please check your login or password." I have tried copying old versions of config.json. I can't get past this screen.
4. In the end I blew that version of z-wave-server away and restored the rc34 backup - now I can't get that working either.
Am I missing something fundamental here? Before I copy these files I stop, then start the z-wave-server. Is the /opt/z-wave-server directory the only one I have to recover when I roll back to a prior version -are there other directories/files I need to restore?
Right now I am at the point of re-building the whole of the Raspian Pi OS and completely starting again. That will be the third time!
I have quite a lot in my config file - will I be able to salvage any of it again?
Finally you asked for what was in the profiles section of my config.json file, here is an example:
"profiles": [{
"id": 1,
"sid": "sua14334552991",
"role": 1,
"login": "admin",
"password": "admin",
"name": "Administrator",
"last_login": null,
"lang": "en",
"color": "#dddddd",
"default_ui": 1,
"dashboard": ["ZWayVDev_zway_20-1-48-1",
"ZWayVDev_zway_20-2-48-1"],
"interval": 2000,
"rooms": [],
"expert_view": false,
"hide_all_device_events": false,
"hide_system_events": false,
"hide_single_device_events": [],
"positions": []
Any help very welcome!
Many thanks
"profiles": [{
"id": 1,
"role": 1,
"login": "admin",
"last_login": null,
"lang": "en",
"color": "#dddddd",
"default_ui": 1,
"interval": 2000,
"rooms": [],
"positions": []
Many thanks
