Version 2.0.1 Not Living Up to Expectation
islipfd19
Post by islipfd19 »
So I tried version 2.0.1 today and it doesn't quite live up to expectations.
  • Door Locks are non-functional
  • I'm unable to access or use the zwave app on my android phone
  • It no longer sees my aeon flood sensor
Though I will give credit to the new design layout, it will have to get use to using it; that's when I decide to update to 2.0.1 again or actually its predecessor.
Re: Version 2.0.1 Not Living Up to Expectation
FWIW: on http://razberry.z-wave.me/z-way-server/, there is an update v2.0.2-rc1 that should fix some post release problems. A.o. the problem with saving Device Description records.
Note that 2.0.1 and upper have authentication, so accessing from outside via API requires authentication or correctly set,up Anonymous user
islipfd19
Post by islipfd19 »
Yes, I was aware of that. I added an anonymous user and allowed that user to view all rooms and there was still limited devices in the API - http://raspberrypi:8083/ZAutomation/api/v1/devices
Make sure all devices are in rooms and there rooms are accessible to anonymous.
If you still have problems, please provide us support access
islipfd19
Post by islipfd19 »
I attempted to do that. Unfortunately I've regressed back to 2.0.0 from an IMG I made of the sdcard prior to upgrading to 2.0.1 release.
I will be waiting patiently for the next release, or in my spare time; mess with this one again. Right now I'm just too busy.
islipfd19
Post by islipfd19 »
OK, I took the plunge to the 2.1.1 release a couple days ago since forgoing the 2.0.1 release. I can honestly say that the improvements made definitely makes a difference.
I'm now able to continue to use the custom scripts I wrote that prevented me from retrieving the status of specific devices
Door locks of course are functioning
I found a new app which allows me to monitor and control the devices from my phone
It now sees my flood sensor (it's an everspring, not aeon) although I had to manually wake the device up and force an interview; but when complete zway saw it as expected.
