Set state Code_Device at startup
billyboy
Post by billyboy »
I have a custom JavaScript which I added to my to my Z-Wave.me server to "Load custom JavaScript file"
The functions in this script work great.
I want to set the state of my Code_Devices at startup. For that I added this code:
var portDevices =
"Code_Device_switchBinary_22",
"Code_Device_switchBinary_24",
"Code_Device_switchBinary_25",
"Code_Device_switchBinary_26",
"Code_Device_switchBinary_27",
"Code_Device_switchBinary_28",
"Code_Device_switchBinary_29",
"Code_Device_switchBinary_30"
console.log("Retrieve port states:");
for (var i in portDevices) {
	vDev = controller.devices.get(portDevices[i]);
	var portState = getPortState(i+1);
	console.log("Set "+portDevices[i]+" to "+portState);
	vDev.set('metrics:level', portState);
But sometimes, the Code_Devices are not created before this code is run.
Than I get next error in the log-file:
[2015-07-29 08:09:06.735] [I] [core] Retrieve port states:
[2015-07-29 08:09:07.528] [I] [core] Executing: python /opt/homeControl/port.py get 01 Result: -off-
[2015-07-29 08:09:07.529] [I] [core] Set Code_Device_switchBinary_22 to off
[2015-07-29 08:09:07.658] [E] [core] result: Error: TypeError: Cannot read property 'set' of null
    at automation/myCode.js:28:6
    at automation/modules/CustomUserCodeLoader/index.js:39:13
    at Array.forEach (native)
    at CustomUserCodeLoader.init (automation/modules/CustomUserCodeLoader/index.js:34:33)
    at AutomationController.instantiateModule (automation/classes/AutomationController.js:300:22)
    at AutomationController.<anonymous> (automation/classes/AutomationController.js:392:18)
    at AutomationController.loadModule (automation/classes/AutomationController.js:391:8)
    at AutomationController.<anonymous> (automation/classes/AutomationController.js:409:14)
[2015-07-29 08:09:07.720] [I] [core] Notification: error (core): Cannot instantiate module: CustomUserCodeLoader: Error: Uncaught TypeError: Cannot read property 'set' of null
[2015-07-29 08:09:07.756] [I] [core] Error: Uncaught TypeError: Cannot read property 'set' of null
    at Error (native)
[2015-07-29 08:09:07.758] [I] [core] Loading module MultilineSensor from modules/MultilineSensor
[2015-07-29 08:09:07.764] [I] [core] Executing script: /*** MultilineSensor Z-Way HA module ******************************************* ...
[2015-07-29 08:09:07.769] [I] [core] Loading module CodeDevice from modules/CodeDevice
[2015-07-29 08:09:07.775] [I] [core] Executing script: /*** CodeDevice Z-Way HA module ******************************************* ...
[2015-07-29 08:09:07.799] [I] [core] Instantiating module 22 from class CodeDevice
[2015-07-29 08:09:07.809] [I] [core] --- Starting module Code Device
[2015-07-29 08:09:07.843] [I] [core] Creating device switchBinary Code_Device_switchBinary_22
[2015-07-29 08:09:07.989] [I] [core] Instantiating module 24 from class CodeDevice
[2015-07-29 08:09:07.991] [I] [core] --- Starting module Code Device
[2015-07-29 08:09:08.016] [I] [core] Creating device switchBinary Code_Device_switchBinary_24
[2015-07-29 08:09:08.078] [I] [core] Instantiating module 25 from class CodeDevice
[2015-07-29 08:09:08.079] [I] [core] --- Starting module Code Device
[2015-07-29 08:09:08.127] [I] [core] Creating device switchBinary Code_Device_switchBinary_25
[2015-07-29 08:09:08.159] [I] [core] Instantiating module 26 from class CodeDevice
[2015-07-29 08:09:08.160] [I] [core] --- Starting module Code Device
[2015-07-29 08:09:08.179] [I] [core] Creating device switchBinary Code_Device_switchBinary_26
[2015-07-29 08:09:08.213] [I] [core] Instantiating module 27 from class CodeDevice
[2015-07-29 08:09:08.213] [I] [core] --- Starting module Code Device
[2015-07-29 08:09:08.233] [I] [core] Creating device switchBinary Code_Device_switchBinary_27
[2015-07-29 08:09:08.265] [I] [core] Instantiating module 28 from class CodeDevice
[2015-07-29 08:09:08.265] [I] [core] --- Starting module Code Device
[2015-07-29 08:09:08.285] [I] [core] Creating device switchBinary Code_Device_switchBinary_28
[2015-07-29 08:09:08.316] [I] [core] Instantiating module 29 from class CodeDevice
[2015-07-29 08:09:08.317] [I] [core] --- Starting module Code Device
[2015-07-29 08:09:08.337] [I] [core] Creating device switchBinary Code_Device_switchBinary_29
[2015-07-29 08:09:08.371] [I] [core] Instantiating module 30 from class CodeDevice
[2015-07-29 08:09:08.371] [I] [core] --- Starting module Code Device
[2015-07-29 08:09:08.391] [I] [core] Creating device switchBinary Code_Device_switchBinary_30
[2015-07-29 08:09:08.424] [I] [core] Instantiating module 31 from class CodeDevice
[2015-07-29 08:09:08.454] [I] [core] --- Starting module Code Device
As you can see the Code_Devices are created later.
How can I fix this?
Re: Set state Code_Device at startup
The device does not exist at the time Custom Code is loaded. You need to listen for device creation and then set it's value
billyboy
Post by billyboy »
Hi PoltoS,
Thanks for your reply. Can you give me a example how to do this?
billyboy
Post by billyboy »
Can no one help me?
