How to change RaZberry Remote Access ID
Locked
olexander
Post by olexander »
I have my SD card image that I took from my RaZberry installation.
I wrote this image to another SD card to be used on different installation.
However the second controller got the same RaZberry Remote Access ID and find.z-wave.me is not able to access it.
How can I correctly change the RaZberry Remote Access ID?
Is there any script to update the Remote Access ID if z-way-server runs on different hardware?
AlphaX2
Re: How to change RaZberry Remote Access ID
Post by AlphaX2 »
You can in theory change your ID with nano, it's saved in: /etc/zbw/userid. But I'm not sure, if this is enough.
As far as I know: you can try deleting all Z-Way related stuff from Raspberry and install Z-Way again, it will change/create new ID, because it's recognized as fresh install.
AlphaX2
no, editing this file will not help. You need to make a fresh install. write us on info@ or support@ and we will help you with this.
olexander
Post by olexander »
Thanks, I removed an existing version and installed a fresh version and a new RaZberry Remote Access ID has been assigned:
sudo rm -rf /opt/z-way-server
sudo rm -rf /etc/*/z-way-server
sudo rm -rf /etc/*/zbw*
sudo rm -rf /etc/zbw*
wget -q -O - http://razberry.z-wave.me/install | sudo bash
Z-wave network information (like z-wave devices, rooms, events) was preserved, local user accounts also remained the same.
Locked
