Fibaro Roller Shutter FGRM-222: Controling with HomeKit?
Posted: 02 Oct 2015 14:46
by vga
Hi everyone,
Hardware: Raspberry B+, razberry
Software: Razberry v2.1.1.
I have added Fibaro Roller Shutter FGRM-222. As the actor command class a binaryswitch was recognized.
Controlling the Roller Shutter with this UI switch works.
Now i want to control the Roller Shutter with my HomeKit App.
When telling Siri to close or open the Roller Shutter, Siri is saying that "there are no blinds"
If I telling Siri to torn on the light, my Fibaro WallPlug actor will be turned on AND the Roller Shutter is going up, till I telling Siri to turn off the light! Then the Wall Plug turns off AND the Roller Shutter stops.
What can i do, to control ONLY the Roller Shutter actor over HomeKit?
Best Regards,
Dave
Re: Fibaro Roller Shutter FGRM-222: Controling with HomeKit?
Posted: 02 Oct 2015 16:11
by pofs
It is a shortcoming of current HomeKit module. It currently treats all MultiLevel switches as lightbulbs, so you get what you get. I'll get it fixed it in future releases. Try giving it a name for now, and control it by name.
Generally devices from Z-Wave map to HomeKit pretty bad, especially when they're split into several virtual devices. The next version of module will attempt to join some virtual devices back for HomeKit controllers.
Posted: 02 Oct 2015 17:54
by vga
Ok, thank you pofs.
Posted: 04 Aug 2016 11:13
by lademeister
https://www.npmjs.com/package/homebridge-zway
should be your solution...
You may add a Tag to the Device in Z-Way so that Homekit recognizes the device differently.
You have to use "Homebridge" and "Homebridge-zway" and not the HomeKit-App with is available in zway.
you can get them here:
Quote:
Dimmer or other switchMultilevel as WindowCovering
If you have a shutter/drapery control that uses a percentage value for open/closed, but is not automatically recognized as such (for instance it is instead shown as a light dimmer), you can specify Homebridge.Service.Type:WindowCovering to force it to be recognized correctly. This should not be necessary in most cases.
Posted: 27 Aug 2017 20:23
by ionas
Are there any updates?
I would also install homekit (i already did) and the homebridge-zway package if there is no other solution.
Does it work in the z-wave me program or does it run in homebridge? i like having a nice ui …
thank you!
Posted: 28 Sep 2017 13:09
by stich86
you have to use homebridge-zway if you want to show as "blind\rollershutter" on Home App, otherwise the HomeKit plugin of Z-Way reports as dimmer able light
please note that homebridge-zway seems "abandoned" at the moment, and you need to modify the code to avoid some issue on the "blind\rollershutter" section (just remove al line of code but you will have a cosmetic issue on the Home App when blinds are opening\closing..)
