can not connect to http://192.168.10.5:8083
Posted: 09 Oct 2015 08:56
by zacken542
I have
Raspberry pi 2
Razberry
Raspbian 2015-05-15
I have run following commands
sudo apt-get update
sudo apt-get upgrade
wget -q -O - http://razberry.z-wave.me/install | sudo bash
and in my firefox
working and says it's firmware 2.1
but this is not answer (no connection)
How can I search for clues whats wrong?
Sven Åke
Re: can not connect to http://192.168.10.5:8083
Posted: 09 Oct 2015 22:43
by zacken542
I tryed to download
http://razberry.z-wave.me/z-way-server/razberry.img.zip
to test from this page
http://razberry.z-wave.me/index.php?id=24
to be able to test if it's work
But it's not even booting up me RPI 2
so what can I do now ?
must I connect my Fibaro wall plug before it's start to work
any thing more I can test
this log-file from install
do you see any errors in that?
Do you accept Z-Wave.Me licence agreement?
Please read it on Z-Wave.Me web site: http://razberry.z-wave.me/docs/ZWAYEULA.pdf
yes/no: yes
z-way-server new installation
Removing MathKernel
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages will be REMOVED:
wolfram-engine
0 upgraded, 0 newly installed, 1 to remove and 1 not upgraded.
After this operation, 460 MB disk space will be freed.
(Reading database ... 79484 files and directories currently installed.)
Removing wolfram-engine ...
Processing triggers for shared-mime-info ...
Processing triggers for man-db ...
Processing triggers for hicolor-icon-theme ...
Processing triggers for desktop-file-utils ...
Installing additional libraries
Hit http://raspberrypi.collabora.com wheezy Release.gpg
Hit http://mirrordirector.raspbian.org wheezy Release.gpg
Hit http://archive.raspberrypi.org wheezy Release.gpg
Hit http://raspberrypi.collabora.com wheezy/rpi armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/main armhf Packages
Hit http://archive.raspberrypi.org wheezy/main armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/contrib armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/non-free armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/rpi armhf Packages
Ign http://raspberrypi.collabora.com wheezy/rpi Translation-en_GB
Ign http://archive.raspberrypi.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/rpi Translation-en_GB
Building dependency tree...
tzdata is already the newest version.
Suggested packages:
gawk-doc bsd-mailx mailx
The following NEW packages will be installed:
gawk libsigsegv2 sharutils
0 upgraded, 3 newly installed, 0 to remove and 1 not upgraded.
Need to get 1,164 kB of archives.
After this operation, 3,147 kB of additional disk space will be used.
Get:1 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libsigsegv2 armhf 2.9-4 [28.4 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian/ wheezy/main gawk armhf 1:4.0.1+dfsg-2.1 [943 kB]
Get:3 http://mirrordirector.raspbian.org/raspbian/ wheezy/main sharutils armhf 1:4.11.1-1 [193 kB]
Fetched 1,164 kB in 6s (192 kB/s)
Selecting previously unselected package libsigsegv2.
(Reading database ... 73073 files and directories currently installed.)
Unpacking libsigsegv2 (from .../libsigsegv2_2.9-4_armhf.deb) ...
Setting up libsigsegv2 (2.9-4) ...
Selecting previously unselected package gawk.
(Reading database ... 73083 files and directories currently installed.)
Unpacking gawk (from .../gawk_1%3a4.0.1+dfsg-2.1_armhf.deb) ...
Selecting previously unselected package sharutils.
Unpacking sharutils (from .../sharutils_1%3a4.11.1-1_armhf.deb) ...
Processing triggers for install-info ...
Setting up gawk (1:4.0.1+dfsg-2.1) ...
Setting up sharutils (1:4.11.1-1) ...
Installing additional libraries for HomeKit
The following extra packages will be installed:
libavahi-client-dev libavahi-common-dev libavahi-compat-libdnssd1 libdbus-1-dev
libavahi-client-dev libavahi-common-dev libavahi-compat-libdnssd-dev libavahi-compat-libdnssd1 libdbus-1-dev
0 upgraded, 5 newly installed, 0 to remove and 1 not upgraded.
Need to get 455 kB of archives.
After this operation, 1,346 kB of additional disk space will be used.
Get:1 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libavahi-compat-libdnssd1 armhf 0.6.31-2 [45.1 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libavahi-common-dev armhf 0.6.31-2 [68.5 kB]
Get:3 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libdbus-1-dev armhf 1.6.8-1+deb7u6 [217 kB]
Get:4 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libavahi-client-dev armhf 0.6.31-2 [62.3 kB]
Get:5 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libavahi-compat-libdnssd-dev armhf 0.6.31-2 [62.8 kB]
Fetched 455 kB in 1s (284 kB/s)
Selecting previously unselected package libavahi-compat-libdnssd1:armhf.
(Reading database ... 73241 files and directories currently installed.)
Unpacking libavahi-compat-libdnssd1:armhf (from .../libavahi-compat-libdnssd1_0.6.31-2_armhf.deb) ...
Selecting previously unselected package libavahi-common-dev.
Unpacking libavahi-common-dev (from .../libavahi-common-dev_0.6.31-2_armhf.deb) ...
Selecting previously unselected package libdbus-1-dev.
Unpacking libdbus-1-dev (from .../libdbus-1-dev_1.6.8-1+deb7u6_armhf.deb) ...
Selecting previously unselected package libavahi-client-dev.
Unpacking libavahi-client-dev (from .../libavahi-client-dev_0.6.31-2_armhf.deb) ...
Selecting previously unselected package libavahi-compat-libdnssd-dev.
Unpacking libavahi-compat-libdnssd-dev (from .../libavahi-compat-libdnssd-dev_0.6.31-2_armhf.deb) ...
Setting up libavahi-compat-libdnssd1:armhf (0.6.31-2) ...
Setting up libavahi-common-dev (0.6.31-2) ...
Setting up libdbus-1-dev (1.6.8-1+deb7u6) ...
Setting up libavahi-client-dev (0.6.31-2) ...
Setting up libavahi-compat-libdnssd-dev (0.6.31-2) ...
Making symlinks to libssl.so
Making symlinks to libcrypto.so
Getting Z-Way for Raspberry Pi and installing
--2015-10-09 17:58:29-- http://razberry.z-wave.me/z-way-server/z-way-server-RaspberryPiXTools-v2.1.1.tgz
Resolving razberry.z-wave.me (razberry.z-wave.me)... 46.20.244.36
Connecting to razberry.z-wave.me (razberry.z-wave.me)|46.20.244.36|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 15865798 (15M) [application/x-gzip]
Saving to: `/tmp/z-way-server-RaspberryPiXTools-v2.1.1.tgz'
100%[==============================================================================>] 15,865,798 888K/s in 24s
2015-10-09 17:58:53 (654 KB/s) - `/tmp/z-way-server-RaspberryPiXTools-v2.1.1.tgz' saved [15865798/15865798]
Extracting new z-way-server
New version z-way-server installed
Creating Z-Way startup script
Adding z-way-server to autostart
update-rc.d: using dependency based boot sequencing
Getting Webif for Raspberry Pi and installing
--2015-10-09 17:58:56-- http://razberry.z-wave.me/webif_raspberry.tar.gz
Length: 401379 (392K) [application/x-gzip]
Saving to: `STDOUT'
100%[==============================================================================>] 401,379 531K/s in 0.7s
2015-10-09 17:58:57 (531 KB/s) - written to stdout [401379/401379]
First install, getting razberry ID
--2015-10-09 17:58:57-- http://find.zwave.me/zbw_new_user
Resolving find.zwave.me (find.zwave.me)... 46.20.244.72
Connecting to find.zwave.me (find.zwave.me)|46.20.244.72|:80... connected.
Length: unspecified [application/octet-stream]
Saving to: `/tmp/zbw_connect_setup.run'
[ <=> ] 5,914 232B/s in 26s
2015-10-09 17:59:25 (232 B/s) - `/tmp/zbw_connect_setup.run' saved [5914]
Now you can run zbw_connect with /etc/init.d/zbw_connect start
or simply reboot your system
Your user id: 34468
Your password: eL4OoBah3oRe
[....] Starting zbw_connect:[info] ok.
Getting webserver mongoose for Webif
--2015-10-09 17:59:52-- http://razberry.z-wave.me/mongoose.pkg.rPi.tgz
Length: 44749 (44K) [application/x-gzip]
Saving to: `/tmp/mongoose.pkg.rPi.tgz'
100%[==============================================================================>] 44,749 155K/s in 0.3s
2015-10-09 17:59:52 (155 KB/s) - `/tmp/mongoose.pkg.rPi.tgz' saved [44749/44749]
Adding mongoose to autostart
Start mongoose http server
ls: cannot access config/zddx/*.xml: No such file or directory
Usage: ./z-cfg-update <filename>
Preparing AMA0 interface:
removing 'console=ttyAMA0,115200' and 'kgdboc=ttyAMA0,115200' from kernel command line (/boot/cmdline.txt)
removing '*:*:respawn:/sbin/getty ttyAMA0' from /etc/inittab
AMA0 interface reconfigured, please restart Raspberry
Do you want to receive emails with news about RaZberry project?
! Please subscribe again if you did it before 30.03.2013
yes/no: no
Thank you for using RaZberry!
Sven Åke
Posted: 11 Oct 2015 18:13
by zacken542
http://razberry.z-wave.me/index.php?id=29
in this link you see
I just got my RaZberry, but it does not work
If you see in the log on of these lines:
where is this log located?
edit :
on power on red and green led light is on for 1 second after that off
Sven Åke
Posted: 12 Oct 2015 15:51
by zacken542
changed some in iptable and now it at last works !
Sven Åke
Posted: 17 Oct 2015 16:13
by mannanwaheed
I am issue installing razberry too I am in same dilemma as you. The only thing different I see in your case and mine is that you had 8084 working for me that isn't working either. The light on razberry turns on for 1 second and turns off so as you pointed out in Known Issues that seems to be fine. I couldn't find the log either. If you have found the log please let me know how to access it. The folders which Known Issues document has referenced end up saying permission denied. I would highly appreciate if you could highlight how you resolved the issue at your end so that I can try to replicate that and try to fix issues with my device too.
Posted: 31 Oct 2015 13:54
by cyberhofi
My razberry was running fine for the last weeks but now i have the same problem.
I can access port 8084 without problems but port 8083 does not work.
What changes did you make to iptables?
Posted: 13 Nov 2015 17:58
by jonator
cyberhofi wrote:My razberry was running fine for the last weeks but now i have the same problem.
I would love to know as well!
Posted: 13 Nov 2015 18:09
by cyberhofi
I asked zacken542 via PM, here is his reply:
zacken542 wrote:
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet static
address 192.168.10.5
gateway 192.168.10.1
netmask 255.255.255.0
Posted: 13 Nov 2015 19:19
by jonator
cyberhofi wrote:I asked zacken542 via PM, here is his reply:
zacken542 wrote:
auto lo
auto eth0
Spank you alot! Working!
Posted: 02 Jan 2016 08:43
by quazar
I've been struggling with this for quite some time, many thanks for this solution.
