How I do change the parameter from Fibaro FGS 222
Lichtnix
Post by Lichtnix »
Hello i need help!
I have PI 2 with RaZberry
How I do change the parameter from Fibaro FGS 222 Parameter 14 from 0 to 1 and Parameter 4 from 0 to 1 second.
Thank you for your help.
Re: How I do change the parameter from Fibaro FGS 222
/JS/Run/zway.devices[XX].Configuration.Set(14, 1)
But it should also be possible from the UI if ZDDX record was detected
