Support for RGB LED controllers
vantomas
Post by vantomas »
I'm new to Z-Wave products and I'm interested into Z-Way solution, but I have some questions.
I want to ask about support for RGB LED controller. I want to control RGB LED strip for light, so I find some Z-Wave compatible controller FIB_FGRGB-101 which may be supported by Z-WAY, but before than I buy everything, I want to ask if it is supported (or if you can recommend some other supported controller) and how is looking UI in Android app about configuring colors.
One of thing which is important is save favorite colors and I can't find anywhere screenshots from app how color set looks. I want to switch between favorite colors and I don't want to set colors on three sliders.
Can you make some screenshots from app where I can see how looks setting of color and how looks saved presets?
Thank you.
T.
roha
Re: Support for RGB LED controllers
Post by roha »
I'm using 4 Firbaro RGBW controllers now with z-way and I'm quite happy with them.
Controller:
http://www.fibaro.com/manuals/en/FGRGBW ... .1-2.3.pdf
LEDs I use:
http://www.amazon.de/gp/product/B00QI8OK4K
Regarding favorite colors I used Light Scenes to store my favorite colors. These can be easily activated with the app.
jhmartin
Post by jhmartin »
Has anyone used the Aeotec LED strip (ZW121) ?
AlphaX2
Post by AlphaX2 »
I'm also using the Fibaro RGBW controller and it's fully working and supported.
The "app" is nothing more than the website. You have a color picker element, but you can't save the color directly, I'm using the JS-Code-Device to create pre-defined colors as toogle button element.
AlphaX2
