How to upgrade RaZberry firmware?
cyberhofi
Post by cyberhofi »
the changelog of v2.1.2-rc15 says i have to upgrade the firmware the 5.04.
The expert UI says i have Firmware 5.0 so how do i upgrade to 5.04?
On the razberry homepage i can not find any documentation about this.
Torulf
Re: How to upgrade RaZberry firmware?
Post by Torulf »
Hi
Did you find the solution to this? Im on v2.1.2-cr17 and my Razberry seems to be on firmware 5.00
Or am i wrong?
SDK Version: 6.51.03
Serial API Version: 05.00
branek
Post by branek »
I have the same question, how to update Serial API Version on razberry?
Will be available in next release candidate.
But you can also do it now via direct line:
localhost:8083/expert/#/uzb
mstill
Post by mstill »
Hi gents, I have just updated the firmware via the link stated in the earlier post.
Tried to do the same with the boatloader (2015-11-12 5.4 Update bootloader for 05.04 to 538d) afterwards, but I'm not successful in doing so. The site just throws the following exception: "Error handling data"
Now the z-wave board seems no longer to respond to commands of the raspberry, meaning, i can no longer switch any actor.
Any idea how i can fix that again?
Torulf
Post by Torulf »
mstill wrote:Hi gents, I have just updated the firmware via the link stated in the earlier post.
First Updated bootloader ( 5 Update bootloader for 5 to 538d) then updated firmware to 5.04
Did a "Factory reset" Rebooted (power off/on) and added one device (Aeonlabs Gen 5 breaker)
Had some trouble when adding device but second attempt was successful.
Now is says:
SDK Version: 6.51.06
Serial API Version: 05.04
When looking at "localhost:8083/expert/#/uzb" there is a "update": 5.4 Update bootloader for 05.04 to 538d
Should i attempt to install that or is the one above the same?
qbawawa
Post by qbawawa »
I'm trying to make upgrade of bootloader "Update bootloader for 01.00 to 538d" but also get "Error handling data" message.
stokni
Post by stokni »
qbawawa wrote:I'm trying to make upgrade of bootloader "Update bootloader for 01.00 to 538d" but also get "Error handling data" message.
Same issue, tried it with 2.1.1 and 2.1.2-Rc17 on a clean install of wheezy, but both give "Error handling data from server" Cannot upgrade firmware, is there a way to do this via cli?
fableman
Post by fableman »
After updating to new firmware and boot loader I get this, when I try to turn on/off a switch
[2015-12-02 11:02:12.404] [zway] Adding job: SwitchBinary Set
[2015-12-02 11:02:12.404] [zway] Adding job: SwitchBinary Get
[2015-12-02 11:02:12.404] [D] [zway] SENDING (cb 0x04): ( 01 0A 00 13 33 03 25 01 00 25 04 D3 )
[2015-12-02 11:02:12.407] [D] [zway] RECEIVED ACK
[2015-12-02 11:02:12.407] [D] [zway] RECEIVED: ( 01 04 01 13 00 E9 )
[2015-12-02 11:02:12.407] [D] [zway] SENT ACK
[2015-12-02 11:02:12.407] [zway] Job 0x13 (SwitchBinary Set): Could not be delivered to Z-Wave stack
[2015-12-02 11:02:12.407] [D] [zway] SENDING (cb 0x04): ( 01 0A 00 13 33 03 25 01 00 25 04 D3 )
[2015-12-02 11:02:12.414] [D] [zway] RECEIVED ACK
[2015-12-02 11:02:12.414] [D] [zway] RECEIVED: ( 01 04 01 13 00 E9 )
[2015-12-02 11:02:12.415] [D] [zway] SENT ACK
[2015-12-02 11:02:12.415] [zway] Job 0x13 (SwitchBinary Set): Could not be delivered to Z-Wave stack
[2015-12-02 11:02:12.415] [D] [zway] SENDING (cb 0x04): ( 01 0A 00 13 33 03 25 01 00 25 04 D3 )
[2015-12-02 11:02:12.424] [D] [zway] RECEIVED ACK
[2015-12-02 11:02:12.424] [D] [zway] RECEIVED: ( 01 04 01 13 00 E9 )
[2015-12-02 11:02:12.424] [D] [zway] SENT ACK
[2015-12-02 11:02:12.424] [zway] Job 0x13 (SwitchBinary Set): Could not be delivered to Z-Wave stack
[2015-12-02 11:02:12.425] [zway] Job 0x13 (SwitchBinary Set): Removing job due to too much retransmitions
[2015-12-02 11:02:12.425] [D] [zway] Job 0x13 (SwitchBinary Set): fail
[2015-12-02 11:02:12.425] [zway] Removing job: SwitchBinary Set
[2015-12-02 11:02:12.425] [D] [zway] SENDING (cb 0x05): ( 01 09 00 13 33 02 25 02 25 05 D3 )
[2015-12-02 11:02:12.434] [D] [zway] RECEIVED ACK
[2015-12-02 11:02:12.434] [D] [zway] RECEIVED: ( 01 04 01 13 00 E9 )
[2015-12-02 11:02:12.435] [D] [zway] SENT ACK
[2015-12-02 11:02:12.435] [zway] Job 0x13 (SwitchBinary Get): Could not be delivered to Z-Wave stack
[2015-12-02 11:02:12.435] [D] [zway] SENDING (cb 0x05): ( 01 09 00 13 33 02 25 02 25 05 D3 )
[2015-12-02 11:02:12.444] [D] [zway] RECEIVED ACK
[2015-12-02 11:02:12.444] [D] [zway] RECEIVED: ( 01 04 01 13 00 E9 )
[2015-12-02 11:02:12.444] [D] [zway] SENT ACK
[2015-12-02 11:02:12.444] [zway] Job 0x13 (SwitchBinary Get): Could not be delivered to Z-Wave stack
[2015-12-02 11:02:12.445] [D] [zway] SENDING (cb 0x05): ( 01 09 00 13 33 02 25 02 25 05 D3 )
[2015-12-02 11:02:12.454] [D] [zway] RECEIVED ACK
[2015-12-02 11:02:12.454] [D] [zway] RECEIVED: ( 01 04 01 13 00 E9 )
[2015-12-02 11:02:12.454] [D] [zway] SENT ACK
[2015-12-02 11:02:12.454] [zway] Job 0x13 (SwitchBinary Get): Could not be delivered to Z-Wave stack
[2015-12-02 11:02:12.454] [I] [zway] Job 0x13 (SwitchBinary Get): Removing job due to too much retransmitions
[2015-12-02 11:02:12.454] [D] [zway] Job 0x13 (SwitchBinary Get): fail
[2015-12-02 11:02:12.454] [I] [zway] Removing job: SwitchBinary Get
[2015-12-02 11:02:32.717] [D] [zway] Job 0x13: deleted from queue
fableman
Post by fableman »
After I set the freq to EU (even that it showed EU)
[2015-12-02 11:05:15.350] [D] [zway] SETDATA controller.data.frequency = "EU"
[2015-12-02 11:05:15.350] [zway] Job 0xf2 (Change/Get Z-Wave.Me firmware frequency): Done
[2015-12-02 11:05:15.350] [D] [zway] Job 0xf2 (Change/Get Z-Wave.Me firmware frequency): success
[2015-12-02 11:05:15.350] [zway] Removing job: Change/Get Z-Wave.Me firmware frequency
Things start to work again!
!!! EU is for my controller and frequency/country I live in, you should set to what ever you should) !!!
suggestion: I think the update routine should check what freq the controller is running,and after the update it should SET the freq on controller automatically.
