How to upgrade RaZberry firmware?
Re: How to upgrade RaZberry firmware?
in fact, a simple chip reboot would be enough. Freq change does it too, so it worked for you
G400
Post by G400 »
Where do you set the frequency?
I assume it is stored in some config file, but what is the name and location of the file?
gabrielb
Post by gabrielb »
How come "Start inclusion" wont work anymore efter upgrade? I can use "start exclusion" but only gets error when trying to add devices.
Errormessage follows: "Error handling data /Zwave.zway/Run/controller.AddNoteToNetwork(1)"
Same behaviour as before, when I didnt have a licensecode applied to my UZB1.
cyberhofi
Post by cyberhofi »
G400 wrote:Where do you set the frequency?
Log in first an then go to https://find.z-wave.me/expert/#/network/control.
In the bottom left you can select your frequency.
REXBlack
Post by REXBlack »
gabrielb wrote:How come "Start inclusion" wont work anymore efter upgrade? I can use "start exclusion" but only gets error when trying to add devices.
Hi, have got the same problem, after upgrading. Have you find the solution? To confirm the EU freq do not seems to be the right solution.....in may case.
TK
REXBlack
Post by REXBlack »
these 2 post are connected!!
read: https://forum.z-wave.me/viewtopic.php?f=3419&t=22296
herbert-f
Post by herbert-f »
I have a problem with upgrade the firmware (bootloader upgrade) at my new razberry (Update bootloader for 01.00 to 538d).
The installed software is v.2.2.1.
When I tried tu upgrade the firmware, it comes "Error handling data" and at the log:
[2016-03-07 21:29:26.490] [core] Failed to download bootloader: Not Found
[2016-03-07 21:29:28.590] [core] Failed to download bootloader: Not Found
Can I download and install the bootloader upgrad manually?
Bye
herbert
Plainsane
Post by Plainsane »
herbert-f wrote: Can I download and install the bootloader upgrad manually?
Yes, please? I really want to upgrade my firmware but I can not. I'm very frustrated as I always have to manually complete interview results.
Ricard1
Post by Ricard1 »
PoltoS... Why do you just ignore everyone with same problem, Bootloader/Firmware upgrade error "Error handling data" :?:
Well I dont care anymore, I will look for another brand controller and move to Windows based installation.
Could be fun to end the Razberry suffering in the MWO. :lol:
Bye!
remoticz
Post by remoticz »
If you have problems like this, go to the place where you bought it. In most legislations the shop where you bought it is the first responsible. It is their duty to deliver you a functional product. Many shops (especially webshops) are evading that responsibility. Just as most software vendors do. If something is broken in their software the advise is to buy the upgrade. Your garage doesn't get away with such an answer. Still the law is equally applicable to garages and software/computer vendors....
v2.1.1 raspi2
