I have the same error after i did a controller reset to factory defaults. Never got it back. Interview does not complete and Command Classes for the controller are repeated, like so:
Basic, ApplicationStatus, SwitchBinary, SwitchMultilevel, SceneActivation, ClimateControlSchedule, CRC16, AssociationGroupInformation, DeviceResetLocally, CentralScene, ZWavePlusInfo, MultiChannel, ManufacturerSpecific, PowerLevel, NodeNaming, Clock, Association, Version, Time, MultiChannelAssociation, MultiCmd, Security, Basic, SwitchBinary, SwitchMultilevel, SceneActivation, CentralScene, Basic, SwitchBinary, SwitchMultilevel, SceneActivation, CentralScene, Basic, SwitchBinary, SwitchMultilevel, SceneActivation, CentralScene, Basic, SwitchBinary, SwitchMultilevel, SceneActivation, CentralScene, Basic, SwitchBinary, SwitchMultilevel, SceneActivation, CentralScene, Basic, SwitchBinary, SwitchMultilevel, SceneActivation, CentralScene, Basic, SwitchBinary, SwitchMultilevel, SceneActivation, CentralScene, Basic, SwitchBinary, SwitchMultilevel, SceneActivation, CentralScene, Basic, SwitchBinary, SwitchMultilevel, SceneActivation, CentralScene, Basic, SwitchBinary, SwitchMultilevel, SceneActivation, CentralScene, Basic, SwitchBinary, SwitchMultilevel, SceneActivation, CentralScene, Basic, SwitchBinary, SwitchMultilevel, SceneActivation, CentralScene, Basic, SwitchBinary, SwitchMultilevel, SceneActivation, CentralScene, Basic, SwitchBinary, SwitchMultilevel, SceneActivation, CentralScene, Basic, SwitchBinary, SwitchMultilevel, SceneActivation, CentralScene, Basic, SwitchBinary, SwitchMultilevel, SceneActivation, CentralScene,
When running with Open Zwave Control panel I the following error on the logs
2016-01-04 22:27:50.885 contrlr, Sending (Command) message (Attempt 2, Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2016-01-04 22:27:50.886 Notification: Notification home c99918d3 node 255 Timeout
2016-01-04 22:27:50.888 WARNING: Out of frame flow! (0x47). Sending NAK.
2016-01-04 22:27:50.889 WARNING: Out of frame flow! (0x47). Sending NAK.
2016-01-04 22:27:50.890 WARNING: Out of frame flow! (0xa0). Sending NAK.
2016-01-04 22:27:50.891 WARNING: Out of frame flow! (0x00). Sending NAK.
2016-01-04 22:27:50.892 Unsolicited message received while waiting for ACK.
2016-01-04 22:27:50.893 contrlr, Received: 0x01, 0x07, 0x05, 0x00, 0x01, 0x47, 0x04, 0x00, 0x88
2016-01-04 22:27:50.893 contrlr, WARNING: Checksum incorrect - sending NAK
2016-01-04 22:27:50.894 Unsolicited message received while waiting for ACK.
2016-01-04 22:27:51.395 WARNING: 500ms passed without reading the rest of the frame...aborting frame read
2016-01-04 22:27:51.396 WARNING: Out of frame flow! (0x00). Sending NAK.
2016
Controller page on the expert UI is all blank. Info like the one bellow as not data
Node Id:
Home Id:
Primary Role:
Primary Capability:
SUC/SIS in network:
In the Show Controller data I get:
None (23:04)
nodeId: 1 (23:04)
homeId: -912713517 (23:04)
SUCNodeId: 1 (23:04)
isPrimary: true (23:04)
isInOthersNetwork: false (23:04)
isRealPrimary: true (23:04)
isSUC: true (23:04)
SISPresent: true (23:04)
libType: Static Controller (23:04)
SDK: 6.51.03 (23:04)
ZWlibMajor: 3 (23:04)
ZWlibMinor: 99 (23:04)
ZWLib: 1 (23:04)
ZWVersion: 5 (23:04)
ZWaveChip: ZW0500 (23:04)
APIVersion: 05.00 (23:04)
manufacturerId: 327 (23:04)
vendor: RaZberry by Z-Wave.Me (23:04)
manufacturerProductType: 1024 (23:04)
manufacturerProductId: 1 (23:04)
capabilities: 2,3,4,5,6,7,8,9,10,16,17,18,19,20,21,22,23,24,28,32,33,34,35,36,39,40,41,42,43,44,45,65,66,68,69,70,71,72,73,74,75,76,77,80,81,83,84,85,86,87,94,96,97,98,99,102,103,120,128,144,146,147,152,180,182,183,184,185,186,189,190,191,210,211,212,239,242,244 (23:04)
controllerState: 0 (23:04)
nonManagmentJobs: 0 (23:04)
lastIncludedDevice: None (23:04)
lastExcludedDevice: None (23:04)
secureInclusion: true (23:04)
oldSerialAPIAckTimeout10ms: 10 (23:04)
oldSerialAPIByteTimeout10ms: 10 (23:04)
curSerialAPIAckTimeout10ms: 10 (23:04)
curSerialAPIByteTimeout10ms: 10 (23:04)
countJobs: false (23:04)
memoryGetAddress: None (23:04)
memoryGetData: None (23:04)
functionClasses: 2,3,4,5,6,7,8,18,19,21,22,23,32,33,34,35,36,39,41,42,43,44,45,65,66,68,70,71,72,73,74,75,76,77,80,81,82,83,84,85,86,87,96,97,98,99,128,186,190,210,211,242,243,244,245 (23:04)
functionClassesNames: SerialAPIGetInitData,SerialAPIApplicationNodeInformation,ApplicationCommandHandler,GetControllerCapabilities,SerialAPISetTimeouts,GetSerialAPICapabilities,SerialAPISoftReset,SendNodeInformation,SendData,GetVersion,SendDataAbort,RFPowerLevelSet,GetHomeId,MemoryGetByte,MemoryPutByte,MemoryGetBuffer,MemoryPutBuffer,FlashAutoProgSet,NVMGetId,NVMExtReadLongBuffer,NVMExtWriteLongBuffer,NVMExtReadLongByte,NVMExtWriteLongByte,GetNodeProtocolInformation,SetDefault,ReplicationReceiveComplete,AssignReturnRoute,DeleteReturnRoute,RequestNodeNeighbourUpdate,ApplicationNodeUpdate,AddNodeToNetwork,RemoveNodeFromNetwork,CreateNewPrimary,ControllerChange,SetLearnMode,AssignSUCReturnRoute,EnableSUC,RequestNetworkUpdate,SetSUCNodeId,DeleteSUCReturnRoute,GetSUCNodeId,SendSUCNodeId,RequestNodeInformation,RemoveFailedNode,IsFailedNode,ReplaceFailedNode,GetRoutingTableLine,RFPowerLevelGet,SendTestFrame,WatchDogStart,WatchDogStop,ZMEFreqChange,ZMERestore,ZMEBootloaderFlash,ZMECapabilities (23:04)
softwareRevisionVersion: v2.2.0 (23:04)
softwareRevisionId: 409e9bc1420acd7c5c8739b9313f1863c9e7dcdd (23:04)
softwareRevisionDate: 2015-12-12 00:30:59 +0300 (23:04)
uuid: None (23:04)
caps: None (23:04)
frequency: unknown (23:04)
I've tried to set the frequency to US in the expert UI and by hand in the config/zddx/c99918d3-DevicesData.xml and it always changes back to Unkown after z-ware-server restart.
[2016-01-04 22:59:08.553] [D] [zway] 0xf2 ZMEFreqChange
[2016-01-04 22:59:08.558] [D] [zway] SETDATA controller.data.frequency = "unknown"
[2016-01-04 22:59:08.558] [E] [zway] Error returned from zway_fc_zme_freq_change(zway, 0xFF, NULL, NULL, NULL): Function class not supported by the hardware (-4)
Installed version 2.2.0 today and nothing changed. What can we do to fix this?
