Razberry stopped working properly
Locked
cyberhofi
Post by cyberhofi »
My razberry stopped working, i am not able to do the a interview with any device even it is not possible to interviev the zway controller.
Device Id
1
Device Name
Z-Way
Device type
Static PC Controller
Interview-Status
Device interview stage is not complete
Wireless Activity
 active
Application version
0.0
SDK version
(0.0)
If i manually interview the device i get
Error handling data
/ZWave.zway/Run/devices[1].instances[0].commandClasses[32].Interview()
Can anybody tell me whats the problem. I tried a fresh install, resetting the controller, changing frequency, upgrading firmware etc.
cyberhofi
Re: Razberry stopped working properly
Post by cyberhofi »
This is the full result of the controller interview
[2015-12-08 16:37:45.248] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.interviewDone = False
[2015-12-08 16:37:45.248] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.interviewCounter = 10 (0x0000000a)
[2015-12-08 16:37:45.249] [D] [zway] SETDATA devices.1.instances.0.commandClasses.34.data.interviewDone = False
[2015-12-08 16:37:45.249] [D] [zway] SETDATA devices.1.instances.0.commandClasses.34.data.interviewCounter = 10 (0x0000000a)
[2015-12-08 16:37:45.249] [D] [zway] SETDATA devices.1.instances.0.commandClasses.37.data.interviewDone = False
[2015-12-08 16:37:45.249] [D] [zway] SETDATA devices.1.instances.0.commandClasses.37.data.interviewCounter = 10 (0x0000000a)
[2015-12-08 16:37:45.249] [D] [zway] SETDATA devices.1.instances.0.commandClasses.38.data.interviewDone = False
[2015-12-08 16:37:45.249] [D] [zway] SETDATA devices.1.instances.0.commandClasses.38.data.interviewCounter = 10 (0x0000000a)
[2015-12-08 16:37:45.250] [D] [zway] SETDATA devices.1.instances.0.commandClasses.43.data.interviewDone = False
[2015-12-08 16:37:45.250] [D] [zway] SETDATA devices.1.instances.0.commandClasses.43.data.interviewCounter = 10 (0x0000000a)
[2015-12-08 16:37:45.250] [D] [zway] SETDATA devices.1.instances.0.commandClasses.70.data.interviewDone = False
[2015-12-08 16:37:45.250] [D] [zway] SETDATA devices.1.instances.0.commandClasses.70.data.interviewCounter = 10 (0x0000000a)
[2015-12-08 16:37:45.250] [D] [zway] SETDATA devices.1.instances.0.commandClasses.86.data.interviewDone = False
[2015-12-08 16:37:45.250] [D] [zway] SETDATA devices.1.instances.0.commandClasses.86.data.interviewCounter = 10 (0x0000000a)
[2015-12-08 16:37:45.251] [D] [zway] SETDATA devices.1.instances.0.commandClasses.89.data.interviewDone = False
[2015-12-08 16:37:45.251] [D] [zway] SETDATA devices.1.instances.0.commandClasses.89.data.interviewCounter = 10 (0x0000000a)
[2015-12-08 16:37:45.251] [D] [zway] SETDATA devices.1.instances.0.commandClasses.90.data.interviewDone = False
[2015-12-08 16:37:45.251] [D] [zway] SETDATA devices.1.instances.0.commandClasses.90.data.interviewCounter = 10 (0x0000000a)
[2015-12-08 16:37:45.251] [D] [zway] SETDATA devices.1.instances.0.commandClasses.91.data.interviewDone = False
[2015-12-08 16:37:45.252] [D] [zway] SETDATA devices.1.instances.0.commandClasses.91.data.interviewCounter = 10 (0x0000000a)
[2015-12-08 16:37:45.252] [D] [zway] SETDATA devices.1.instances.0.commandClasses.94.data.interviewDone = False
[2015-12-08 16:37:45.252] [D] [zway] SETDATA devices.1.instances.0.commandClasses.94.data.interviewCounter = 10 (0x0000000a)
[2015-12-08 16:37:45.252] [D] [zway] SETDATA devices.1.instances.0.commandClasses.96.data.interviewDone = False
[2015-12-08 16:37:45.252] [D] [zway] SETDATA devices.1.instances.0.commandClasses.96.data.interviewCounter = 10 (0x0000000a)
[2015-12-08 16:37:45.252] [D] [zway] SETDATA devices.1.instances.0.commandClasses.114.data.interviewDone = False
[2015-12-08 16:37:45.253] [D] [zway] SETDATA devices.1.instances.0.commandClasses.114.data.interviewCounter = 10 (0x0000000a)
[2015-12-08 16:37:45.253] [D] [zway] SETDATA devices.1.instances.0.commandClasses.115.data.interviewDone = False
[2015-12-08 16:37:45.253] [D] [zway] SETDATA devices.1.instances.0.commandClasses.115.data.interviewCounter = 10 (0x0000000a)
[2015-12-08 16:37:45.253] [D] [zway] SETDATA devices.1.instances.0.commandClasses.119.data.interviewDone = False
[2015-12-08 16:37:45.253] [D] [zway] SETDATA devices.1.instances.0.commandClasses.119.data.interviewCounter = 10 (0x0000000a)
[2015-12-08 16:37:45.253] [D] [zway] SETDATA devices.1.instances.0.commandClasses.129.data.interviewDone = False
[2015-12-08 16:37:45.253] [D] [zway] SETDATA devices.1.instances.0.commandClasses.129.data.interviewCounter = 10 (0x0000000a)
[2015-12-08 16:37:45.254] [D] [zway] SETDATA devices.1.instances.0.commandClasses.133.data.interviewDone = False
[2015-12-08 16:37:45.254] [D] [zway] SETDATA devices.1.instances.0.commandClasses.133.data.interviewCounter = 10 (0x0000000a)
[2015-12-08 16:37:45.254] [D] [zway] SETDATA devices.1.instances.0.commandClasses.134.data.interviewDone = False
[2015-12-08 16:37:45.254] [D] [zway] SETDATA devices.1.instances.0.commandClasses.134.data.interviewCounter = 10 (0x0000000a)
[2015-12-08 16:37:45.254] [D] [zway] SETDATA devices.1.instances.0.commandClasses.138.data.interviewDone = False
[2015-12-08 16:37:45.254] [D] [zway] SETDATA devices.1.instances.0.commandClasses.138.data.interviewCounter = 10 (0x0000000a)
[2015-12-08 16:37:45.255] [D] [zway] SETDATA devices.1.instances.0.commandClasses.143.data.interviewDone = False
[2015-12-08 16:37:45.255] [D] [zway] SETDATA devices.1.instances.0.commandClasses.143.data.interviewCounter = 10 (0x0000000a)
[2015-12-08 16:37:45.255] [D] [zway] SETDATA devices.1.data.keepAwake = False
[2015-12-08 16:37:45.256] [I] [zway] Interview step 1
[2015-12-08 16:37:45.256] [D] [zway] SETDATA devices.1.instances.0.commandClasses.152.data.interviewDone = False
[2015-12-08 16:37:45.256] [D] [zway] SETDATA devices.1.instances.0.commandClasses.152.data.interviewCounter = 9 (0x00000009)
[2015-12-08 16:37:45.256] [I] [zway] Node 1:0 CC Security Interview started
[2015-12-08 16:37:45.256] [I] [zway] Node 1:0 CC Security: sending Scheme Get
[2015-12-08 16:37:45.256] [E] [zway] Dropping packet to myself (node 1)
[2015-12-08 16:37:45.257] [E] [zway] Error returned from (command->cc->interview_handler)(zway, command): Not implemented by the library (-3)
johnsilva
Post by johnsilva »
I have the same error after i did a controller reset to factory defaults. Never got it back. Interview does not complete and Command Classes for the controller are repeated, like so:
Basic, ApplicationStatus, SwitchBinary, SwitchMultilevel, SceneActivation, ClimateControlSchedule, CRC16, AssociationGroupInformation, DeviceResetLocally, CentralScene, ZWavePlusInfo, MultiChannel, ManufacturerSpecific, PowerLevel, NodeNaming, Clock, Association, Version, Time, MultiChannelAssociation, MultiCmd, Security, Basic, SwitchBinary, SwitchMultilevel, SceneActivation, CentralScene, Basic, SwitchBinary, SwitchMultilevel, SceneActivation, CentralScene, Basic, SwitchBinary, SwitchMultilevel, SceneActivation, CentralScene, Basic, SwitchBinary, SwitchMultilevel, SceneActivation, CentralScene, Basic, SwitchBinary, SwitchMultilevel, SceneActivation, CentralScene, Basic, SwitchBinary, SwitchMultilevel, SceneActivation, CentralScene, Basic, SwitchBinary, SwitchMultilevel, SceneActivation, CentralScene, Basic, SwitchBinary, SwitchMultilevel, SceneActivation, CentralScene, Basic, SwitchBinary, SwitchMultilevel, SceneActivation, CentralScene, Basic, SwitchBinary, SwitchMultilevel, SceneActivation, CentralScene, Basic, SwitchBinary, SwitchMultilevel, SceneActivation, CentralScene, Basic, SwitchBinary, SwitchMultilevel, SceneActivation, CentralScene, Basic, SwitchBinary, SwitchMultilevel, SceneActivation, CentralScene, Basic, SwitchBinary, SwitchMultilevel, SceneActivation, CentralScene, Basic, SwitchBinary, SwitchMultilevel, SceneActivation, CentralScene, Basic, SwitchBinary, SwitchMultilevel, SceneActivation, CentralScene,
When running with Open Zwave Control panel I the following error on the logs
2016-01-04 22:27:50.885 contrlr, Sending (Command) message (Attempt 2, Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2016-01-04 22:27:50.886 Notification: Notification home c99918d3 node 255 Timeout
2016-01-04 22:27:50.888 WARNING: Out of frame flow! (0x47). Sending NAK.
2016-01-04 22:27:50.889 WARNING: Out of frame flow! (0x47). Sending NAK.
2016-01-04 22:27:50.890 WARNING: Out of frame flow! (0xa0). Sending NAK.
2016-01-04 22:27:50.891 WARNING: Out of frame flow! (0x00). Sending NAK.
2016-01-04 22:27:50.892 Unsolicited message received while waiting for ACK.
2016-01-04 22:27:50.893 contrlr, Received: 0x01, 0x07, 0x05, 0x00, 0x01, 0x47, 0x04, 0x00, 0x88
2016-01-04 22:27:50.893 contrlr, WARNING: Checksum incorrect - sending NAK
2016-01-04 22:27:50.894 Unsolicited message received while waiting for ACK.
2016-01-04 22:27:51.395 WARNING: 500ms passed without reading the rest of the frame...aborting frame read
2016-01-04 22:27:51.396 WARNING: Out of frame flow! (0x00). Sending NAK.
2016
Controller page on the expert UI is all blank. Info like the one bellow as not data
Node Id:
Home Id:
Primary Role:
Primary Capability:
SUC/SIS in network:
In the Show Controller data I get:
None (23:04)
    nodeId: 1 (23:04)
    homeId: -912713517 (23:04)
    SUCNodeId: 1 (23:04)
    isPrimary: true (23:04)
    isInOthersNetwork: false (23:04)
    isRealPrimary: true (23:04)
    isSUC: true (23:04)
    SISPresent: true (23:04)
    libType: Static Controller (23:04)
    SDK: 6.51.03 (23:04)
    ZWlibMajor: 3 (23:04)
    ZWlibMinor: 99 (23:04)
    ZWLib: 1 (23:04)
    ZWVersion: 5 (23:04)
    ZWaveChip: ZW0500 (23:04)
    APIVersion: 05.00 (23:04)
    manufacturerId: 327 (23:04)
    vendor: RaZberry by Z-Wave.Me (23:04)
    manufacturerProductType: 1024 (23:04)
    manufacturerProductId: 1 (23:04)
    capabilities: 2,3,4,5,6,7,8,9,10,16,17,18,19,20,21,22,23,24,28,32,33,34,35,36,39,40,41,42,43,44,45,65,66,68,69,70,71,72,73,74,75,76,77,80,81,83,84,85,86,87,94,96,97,98,99,102,103,120,128,144,146,147,152,180,182,183,184,185,186,189,190,191,210,211,212,239,242,244 (23:04)
    controllerState: 0 (23:04)
    nonManagmentJobs: 0 (23:04)
    lastIncludedDevice: None (23:04)
    lastExcludedDevice: None (23:04)
    secureInclusion: true (23:04)
    oldSerialAPIAckTimeout10ms: 10 (23:04)
    oldSerialAPIByteTimeout10ms: 10 (23:04)
    curSerialAPIAckTimeout10ms: 10 (23:04)
    curSerialAPIByteTimeout10ms: 10 (23:04)
    countJobs: false (23:04)
    memoryGetAddress: None (23:04)
    memoryGetData: None (23:04)
    functionClasses: 2,3,4,5,6,7,8,18,19,21,22,23,32,33,34,35,36,39,41,42,43,44,45,65,66,68,70,71,72,73,74,75,76,77,80,81,82,83,84,85,86,87,96,97,98,99,128,186,190,210,211,242,243,244,245 (23:04)
    functionClassesNames: SerialAPIGetInitData,SerialAPIApplicationNodeInformation,ApplicationCommandHandler,GetControllerCapabilities,SerialAPISetTimeouts,GetSerialAPICapabilities,SerialAPISoftReset,SendNodeInformation,SendData,GetVersion,SendDataAbort,RFPowerLevelSet,GetHomeId,MemoryGetByte,MemoryPutByte,MemoryGetBuffer,MemoryPutBuffer,FlashAutoProgSet,NVMGetId,NVMExtReadLongBuffer,NVMExtWriteLongBuffer,NVMExtReadLongByte,NVMExtWriteLongByte,GetNodeProtocolInformation,SetDefault,ReplicationReceiveComplete,AssignReturnRoute,DeleteReturnRoute,RequestNodeNeighbourUpdate,ApplicationNodeUpdate,AddNodeToNetwork,RemoveNodeFromNetwork,CreateNewPrimary,ControllerChange,SetLearnMode,AssignSUCReturnRoute,EnableSUC,RequestNetworkUpdate,SetSUCNodeId,DeleteSUCReturnRoute,GetSUCNodeId,SendSUCNodeId,RequestNodeInformation,RemoveFailedNode,IsFailedNode,ReplaceFailedNode,GetRoutingTableLine,RFPowerLevelGet,SendTestFrame,WatchDogStart,WatchDogStop,ZMEFreqChange,ZMERestore,ZMEBootloaderFlash,ZMECapabilities (23:04)
    softwareRevisionVersion: v2.2.0 (23:04)
    softwareRevisionId: 409e9bc1420acd7c5c8739b9313f1863c9e7dcdd (23:04)
    softwareRevisionDate: 2015-12-12 00:30:59 +0300 (23:04)
    uuid: None (23:04)
    caps: None (23:04)
    frequency: unknown (23:04)
I've tried to set the frequency to US in the expert UI and by hand in the config/zddx/c99918d3-DevicesData.xml and it always changes back to Unkown after z-ware-server restart.
[2016-01-04 22:59:08.553] [D] [zway] 0xf2 ZMEFreqChange
[2016-01-04 22:59:08.558] [D] [zway] SETDATA controller.data.frequency = "unknown"
[2016-01-04 22:59:08.558] [E] [zway] Error returned from zway_fc_zme_freq_change(zway, 0xFF, NULL, NULL, NULL): Function class not supported by the hardware (-4)
Installed version 2.2.0 today and nothing changed. What can we do to fix this?
johnsilva
Post by johnsilva »
By running the ZMEFreqChange directly from command line I was able to get some information on the controller data page, but still not working.
echo -ne "\x01\x04\x00\xf2\x03\x09"> /dev/ttyAMA0
And the Network > Control > Operating frequency Change page now shows
Current frequency: unknown
Can be unknown, unsupported or any region (EU/US/RU/....)
which was not there before.
Role in Network
Node Id:	1
Home Id:	0xedc3d76c
Primary Role:	Yes
Primary Capability:	Yes
SUC/SIS in network:	1 (SIS)
Hardware
Vendor:	RaZberry by Z-Wave.Me
Vendors Product ID:	1024 / 1
Z-Wave Chip:	ZW0500
Firmware
Library Type:	Static Controller
SDK Version:	6.51.03
Serial API Version:	05.00
Capabillities:
UUID:
Subvendor:
Nodes limit:
Capabillities:
Z-Way Software Information
Version number:	v2.2.0
Compile-ID:	409e9bc1420acd7c5c8739b9313f1863c9e7dcdd
Compile-Date:	2015-12-12 00:30:59 +0300
UI
UI version	1.0.3
The interview on #1 should not be present. This is controller itself. It is not foul to interview itself ;)
What is not working for you?
kinjo
Post by kinjo »
I am Having irql_not_less_or_equal problem in my PC.
Moderator locked tis old topic.
This latest post does not refer in a sensible way to anything posted previously in this topic
Please open a new topic where you describe your problem in more detail than you have done here
Locked
