My custom JS code looks like:
zway.devices[5].instances[0].commandClasses[113].data[7].event.bind(function() {
if (this.value == 8) {
debugPrint('CHANGED TO: ' + this.value + ' \n');
system('/opt/z-way-server/automation/userModules/send-mail.sh');
debugPrint('After sending mail...');
})Code: Select all
[2015-12-18 09:50:58.142] [D] [zway] RECEIVED: ( 01 09 00 04 00 05 03 20 01 FF 2A )
[2015-12-18 09:50:58.143] [D] [zway] SENT ACK
[2015-12-18 09:50:58.143] [D] [zway] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
[2015-12-18 09:50:58.143] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcNodeId = 5 (0x00000005)
[2015-12-18 09:50:58.143] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcInstanceId = 0 (0x00000000)
[2015-12-18 09:50:58.143] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.level = 255 (0x000000ff)
[2015-12-18 09:50:58.435] [D] [zway] RECEIVED: ( 01 10 00 04 00 05 0A 71 05 00 00 00 FF 07 08 00 00 60 )
[2015-12-18 09:50:58.436] [D] [zway] SENT ACK
[2015-12-18 09:50:58.436] [D] [zway] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
[2015-12-18 09:50:58.436] [D] [zway] SETDATA devices.5.instances.0.commandClasses.113.data.7.eventParameters = byte[0]
[2015-12-18 09:50:58.436] [D] [zway] ( zero-length buffer )
[2015-12-18 09:50:58.436] [D] [zway] SETDATA devices.5.instances.0.commandClasses.113.data.7.event = 8 (0x00000008)
[2015-12-18 09:50:58.438] [D] [zway] SETDATA devices.5.instances.0.commandClasses.113.data.7.eventString = ""
[2015-12-18 09:50:58.439] [D] [zway] SETDATA devices.5.instances.0.commandClasses.113.data.7.status = 255 (0x000000ff)
[2015-12-18 09:50:58.439] [D] [zway] SETDATA devices.5.instances.0.commandClasses.113.data.7 = Empty
[2015-12-18 09:50:58.443] [I] [core] CHANGED TO: 8
[2015-12-18 09:51:00.388] [I] [core] CHANGED TO: 8
[2015-12-18 09:51:02.325] [I] [core] After sending mail...
[2015-12-18 09:51:02.326] [I] [core] CHANGED TO: 8
[2015-12-18 09:51:04.367] [I] [core] After sending mail...
[2015-12-18 09:51:04.369] [I] [core] CHANGED TO: 8
[2015-12-18 09:51:06.286] [I] [core] After sending mail...
[2015-12-18 09:51:06.287] [I] [core] CHANGED TO: 8
[2015-12-18 09:51:08.147] [I] [core] After sending mail...
[2015-12-18 09:51:08.167] [I] [core] Notification: device-info (device-OnOff): {"dev":"Alarm Burglar 5-0-113-7-8 Aeon Labs","l":"on"}Later on, when device wakes up I get even more mails, but according to log, the custom script is not triggered:
[2015-12-18 09:54:51.040] [D] [zway] RECEIVED: ( 01 08 00 04 00 05 02 84 07 77 )
[2015-12-18 09:54:51.041] [D] [zway] SENT ACK
[2015-12-18 09:54:51.041] [D] [zway] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
[2015-12-18 09:54:51.041] [I] [zway] Node 5:0 CC Wakeup: Wakeup notification
[2015-12-18 09:54:51.041] [D] [zway] SETDATA devices.5.instances.0.commandClasses.132.data.lastWakeup = 1450428891 (0x5673c9db)
[2015-12-18 09:54:51.041] [D] [zway] SETDATA devices.5.data.isAwake = True
[2015-12-18 09:54:51.041] [D] [zway] SETDATA devices.5.data.lastSend = 2915759 (0x002c7daf)
[2015-12-18 09:54:51.041] [D] [zway] SETDATA devices.5.data.lastNonceGet = 2914759 (0x002c79c7)
[2015-12-18 09:54:51.042] [D] [zway] Running wakeup handler for node 5
[2015-12-18 09:54:51.042] [D] [zway] SETDATA devices.5.instances.0.commandClasses.132.data.lastSleep = 1450428891 (0x5673c9db)
[2015-12-18 09:54:51.042] [I] [zway] Node 5:0 CC Wakeup: Send node to sleep
[2015-12-18 09:54:51.042] [I] [zway] Adding job: Wakeup Sleep
[2015-12-18 09:54:51.114] [D] [zway] SENDING (cb 0xde): ( 01 0B 00 13 05 04 31 04 01 00 05 DE 09 )
[2015-12-18 09:54:51.117] [D] [zway] RECEIVED ACK
[2015-12-18 09:54:51.121] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-12-18 09:54:51.121] [D] [zway] SENT ACK
[2015-12-18 09:54:51.122] [D] [zway] Delivered to Z-Wave stack
[2015-12-18 09:54:51.136] [D] [zway] RECEIVED: ( 01 07 00 13 DE 00 00 02 37 )
[2015-12-18 09:54:51.136] [D] [zway] SENT ACK
[2015-12-18 09:54:51.137] [I] [zway] Job 0x13 (SensorMultilevel V5 Get): Delivered
[2015-12-18 09:54:51.137] [D] [zway] SETDATA devices.5.data.lastPacketInfo.delivered = True
[2015-12-18 09:54:51.138] [D] [zway] SETDATA devices.5.data.lastPacketInfo.packetLength = 7 (0x00000007)
[2015-12-18 09:54:51.138] [D] [zway] SETDATA devices.5.data.lastPacketInfo.deliveryTime = 15 (0x0000000f)
[2015-12-18 09:54:51.139] [D] [zway] SETDATA devices.5.data.lastPacketInfo = **********
[2015-12-18 09:54:51.139] [D] [zway] SendData Response with callback 0xde received: received by recipient
[2015-12-18 09:54:51.140] [D] [zway] SETDATA devices.5.data.lastSend = 2915768 (0x002c7db8)
[2015-12-18 09:54:51.140] [D] [zway] Job 0x13 (SensorMultilevel V5 Get): success
[2015-12-18 09:54:51.141] [I] [zway] Removing job: SensorMultilevel V5 Get
[2015-12-18 09:54:51.206] [D] [zway] SENDING (cb 0xdf): ( 01 0B 00 13 05 04 31 04 03 08 05 DF 02 )
[2015-12-18 09:54:51.209] [D] [zway] RECEIVED ACK
[2015-12-18 09:54:51.213] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-12-18 09:54:51.213] [D] [zway] SENT ACK
[2015-12-18 09:54:51.214] [D] [zway] Delivered to Z-Wave stack
[2015-12-18 09:54:51.228] [D] [zway] RECEIVED: ( 01 07 00 13 DF 00 00 02 36 )
[2015-12-18 09:54:51.228] [D] [zway] SENT ACK
[2015-12-18 09:54:51.229] [I] [zway] Job 0x13 (SensorMultilevel V5 Get): Delivered
[2015-12-18 09:54:51.229] [D] [zway] SETDATA devices.5.data.lastPacketInfo.delivered = True
[2015-12-18 09:54:51.229] [D] [zway] SETDATA devices.5.data.lastPacketInfo.packetLength = 7 (0x00000007)
[2015-12-18 09:54:51.230] [D] [zway] SETDATA devices.5.data.lastPacketInfo.deliveryTime = 15 (0x0000000f)
[2015-12-18 09:54:51.231] [D] [zway] SETDATA devices.5.data.lastPacketInfo = **********
[2015-12-18 09:54:51.231] [D] [zway] SendData Response with callback 0xdf received: received by recipient
[2015-12-18 09:54:51.232] [D] [zway] SETDATA devices.5.data.lastSend = 2915777 (0x002c7dc1)
[2015-12-18 09:54:51.232] [D] [zway] Job 0x13 (SensorMultilevel V5 Get): success
[2015-12-18 09:54:51.233] [I] [zway] Removing job: SensorMultilevel V5 Get
[2015-12-18 09:54:51.298] [D] [zway] SENDING (cb 0xe0): ( 01 0B 00 13 05 04 31 04 05 00 05 E0 33 )
[2015-12-18 09:54:51.301] [D] [zway] RECEIVED ACK
[2015-12-18 09:54:51.304] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-12-18 09:54:51.304] [D] [zway] SENT ACK
[2015-12-18 09:54:51.305] [D] [zway] Delivered to Z-Wave stack
[2015-12-18 09:54:51.542] [D] [zway] RECEIVED: ( 01 07 00 13 E0 01 00 17 1D )
[2015-12-18 09:54:51.542] [D] [zway] SENT ACK
[2015-12-18 09:54:51.542] [I] [zway] Job 0x13 (SensorMultilevel V5 Get): Not delivered to recipient
[2015-12-18 09:54:51.542] [D] [zway] SETDATA devices.5.data.lastPacketInfo.delivered = False
[2015-12-18 09:54:51.542] [D] [zway] SETDATA devices.5.data.lastPacketInfo.packetLength = 7 (0x00000007)
[2015-12-18 09:54:51.543] [D] [zway] SETDATA devices.5.data.lastPacketInfo.deliveryTime = 237 (0x000000ed)
[2015-12-18 09:54:51.543] [D] [zway] SETDATA devices.5.data.lastPacketInfo = **********
[2015-12-18 09:54:51.543] [D] [zway] SETDATA devices.5.data.isAwake = False
[2015-12-18 09:54:51.543] [D] [zway] Sending the queue for node 5 into sleep
[2015-12-18 09:54:52.113] [D] [zway] RECEIVED: ( 01 0C 00 04 00 05 06 31 05 01 22 00 E0 03 )
[2015-12-18 09:54:52.114] [D] [zway] SENT ACK
[2015-12-18 09:54:52.114] [D] [zway] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
[2015-12-18 09:54:52.114] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2015-12-18 09:54:52.115] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2015-12-18 09:54:52.115] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.1.val = 22.400000
[2015-12-18 09:54:52.117] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2015-12-18 09:54:52.117] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.1 = Empty
[2015-12-18 09:54:52.175] [I] [core] Notification: device-info (device-temperature): {"dev":"Sensor Temperature 5-0-49-1 Aeon
Labs","l":"22.4 °C"}
[2015-12-18 09:54:52.772] [D] [zway] RECEIVED: ( 01 0B 00 04 00 05 05 31 05 05 01 22 E2 )
[2015-12-18 09:54:52.772] [D] [zway] SENT ACK
[2015-12-18 09:54:52.772] [D] [zway] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
[2015-12-18 09:54:52.772] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2015-12-18 09:54:52.772] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2015-12-18 09:54:52.773] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.5.val = 34.000000
[2015-12-18 09:54:52.774] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.5.scaleString = "%"
[2015-12-18 09:54:52.774] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.5 = Empty
[2015-12-18 09:54:58.195] [D] [zway] RECEIVED: ( 01 0C 00 04 00 05 06 31 05 03 0A 00 06 CF )
[2015-12-18 09:54:58.196] [D] [zway] SENT ACK
[2015-12-18 09:54:58.196] [D] [zway] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
[2015-12-18 09:54:58.196] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2015-12-18 09:54:58.196] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2015-12-18 09:54:58.197] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.3.val = 6.000000
[2015-12-18 09:54:58.199] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2015-12-18 09:54:58.199] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.3 = Empty
[2015-12-18 09:54:58.214] [I] [core] Notification: device-info (device-luminiscence): {"dev":"Sensor Luminiscence 5-0-49-3 Aeon
Labs","l":"6 null"}
[2015-12-18 09:54:58.458] [D] [zway] RECEIVED: ( 01 09 00 04 00 05 03 20 01 00 D5 )
[2015-12-18 09:54:58.458] [D] [zway] SENT ACK
[2015-12-18 09:54:58.459] [D] [zway] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
[2015-12-18 09:54:58.459] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcNodeId = 5 (0x00000005)
[2015-12-18 09:54:58.459] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcInstanceId = 0 (0x00000000)
[2015-12-18 09:54:58.459] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.level = 0 (0x00000000)
[2015-12-18 09:54:58.762] [D] [zway] RECEIVED: ( 01 10 00 04 00 05 0A 71 05 00 00 00 FF 07 00 00 00 68 )
[2015-12-18 09:54:58.762] [D] [zway] SENT ACK
[2015-12-18 09:54:58.762] [D] [zway] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
[2015-12-18 09:54:58.763] [D] [zway] SETDATA devices.5.instances.0.commandClasses.113.data.7.eventParameters = byte[0]
[2015-12-18 09:54:58.763] [D] [zway] ( zero-length buffer )
[2015-12-18 09:54:58.763] [D] [zway] SETDATA devices.5.instances.0.commandClasses.113.data.7.event = 0 (0x00000000)
[2015-12-18 09:54:58.765] [D] [zway] SETDATA devices.5.instances.0.commandClasses.113.data.7.eventString = ""
[2015-12-18 09:54:58.765] [D] [zway] SETDATA devices.5.instances.0.commandClasses.113.data.7.status = 255 (0x000000ff)
[2015-12-18 09:54:58.765] [D] [zway] SETDATA devices.5.instances.0.commandClasses.113.data.7 = Empty
[2015-12-18 09:55:02.547] [I] [core] After sending mail...
[2015-12-18 09:55:02.569] [I] [core] Notification: device-info (device-OnOff): {"dev":"Alarm Burglar 5-0-113-7-8 Aeon Labs","l":"off"}Even more later on I get two mails, also unexpected:
[2015-12-18 09:59:50.672] [D] [zway] RECEIVED: ( 01 0C 00 04 00 05 06 31 05 01 22 00 E0 03 )
[2015-12-18 09:59:50.673] [D] [zway] SENT ACK
[2015-12-18 09:59:50.673] [D] [zway] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
[2015-12-18 09:59:50.673] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2015-12-18 09:59:50.674] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2015-12-18 09:59:50.674] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.1.val = 22.400000
[2015-12-18 09:59:50.676] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2015-12-18 09:59:50.676] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.1 = Empty
[2015-12-18 09:59:51.068] [D] [zway] RECEIVED: ( 01 0B 00 04 00 05 05 31 05 05 01 22 E2 )
[2015-12-18 09:59:51.068] [D] [zway] SENT ACK
[2015-12-18 09:59:51.068] [D] [zway] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
[2015-12-18 09:59:51.068] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2015-12-18 09:59:51.068] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2015-12-18 09:59:51.068] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.5.val = 34.000000
[2015-12-18 09:59:51.070] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.5.scaleString = "%"
[2015-12-18 09:59:51.070] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.5 = Empty
[2015-12-18 09:59:52.362] [D] [zway] RECEIVED: ( 01 09 00 04 00 05 03 80 03 64 13 )
[2015-12-18 09:59:52.362] [D] [zway] SENT ACK
[2015-12-18 09:59:52.362] [D] [zway] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
[2015-12-18 09:59:52.363] [D] [zway] SETDATA devices.5.instances.0.commandClasses.128.data.history.100 = 1450429192 (0x5673cb08)
[2015-12-18 09:59:52.363] [D] [zway] SETDATA devices.5.instances.0.commandClasses.128.data.last = 100 (0x00000064)
[2015-12-18 09:59:52.423] [D] [zway] RECEIVED: ( 01 0C 00 04 00 05 06 31 05 03 0A 00 07 CE )
[2015-12-18 09:59:52.424] [D] [zway] SENT ACK
[2015-12-18 09:59:52.424] [D] [zway] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
[2015-12-18 09:59:52.424] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2015-12-18 09:59:52.424] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2015-12-18 09:59:52.424] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.3.val = 7.000000
[2015-12-18 09:59:52.426] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2015-12-18 09:59:52.426] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.3 = Empty
[2015-12-18 09:59:52.434] [I] [core] Notification: device-info (device-luminiscence): {"dev":"Sensor Luminiscence 5-0-49-3 Aeon
Labs","l":"7 null"}
[2015-12-18 09:59:52.515] [D] [zway] RECEIVED: ( 01 0B 00 04 00 05 05 31 05 1B 01 00 DE )
[2015-12-18 09:59:52.515] [D] [zway] SENT ACK
[2015-12-18 09:59:52.515] [D] [zway] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
[2015-12-18 09:59:52.515] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.27.deviceScale = 0 (0x00000000)
[2015-12-18 09:59:52.516] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.27.scale = 0 (0x00000000)
[2015-12-18 09:59:52.516] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.27.val = 0.000000
[2015-12-18 09:59:52.517] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.27.scaleString = "UV index"
[2015-12-18 09:59:52.517] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.27 = Empty
[2015-12-18 09:59:52.575] [D] [zway] RECEIVED: ( 01 08 00 04 00 05 02 84 07 77 )
[2015-12-18 09:59:52.575] [D] [zway] SENT ACK
[2015-12-18 09:59:52.575] [D] [zway] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
[2015-12-18 09:59:52.576] [I] [zway] Node 5:0 CC Wakeup: Wakeup notification
[2015-12-18 09:59:52.576] [D] [zway] SETDATA devices.5.instances.0.commandClasses.132.data.lastWakeup = 1450429192 (0x5673cb08)
[2015-12-18 09:59:52.576] [D] [zway] SETDATA devices.5.data.isAwake = True
[2015-12-18 09:59:52.576] [D] [zway] SETDATA devices.5.data.lastSend = 2945535 (0x002cf1ff)
[2015-12-18 09:59:52.576] [D] [zway] SETDATA devices.5.data.lastNonceGet = 2944535 (0x002cee17)
[2015-12-18 09:59:52.576] [D] [zway] Running wakeup handler for node 5
[2015-12-18 09:59:52.576] [I] [zway] Job 0x13 (Wakeup Sleep): Cancelling job: Wakeup Sleep
[2015-12-18 09:59:52.576] [I] [zway] Removing job: Wakeup Sleep
[2015-12-18 09:59:52.576] [D] [zway] SETDATA devices.5.instances.0.commandClasses.132.data.lastSleep = 1450429192 (0x5673cb08)
[2015-12-18 09:59:52.576] [I] [zway] Node 5:0 CC Wakeup: Send node to sleep
[2015-12-18 09:59:52.576] [I] [zway] Adding job: Wakeup Sleep
[2015-12-18 09:59:52.646] [D] [zway] SENDING (cb 0xe0): ( 01 0B 00 13 05 04 31 04 05 00 05 E0 33 )
[2015-12-18 09:59:52.648] [D] [zway] RECEIVED ACK
[2015-12-18 09:59:52.652] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-12-18 09:59:52.652] [D] [zway] SENT ACK
[2015-12-18 09:59:52.652] [D] [zway] Delivered to Z-Wave stack
[2015-12-18 09:59:52.667] [D] [zway] RECEIVED: ( 01 07 00 13 E0 00 00 02 09 )
[2015-12-18 09:59:52.667] [D] [zway] SENT ACK
[2015-12-18 09:59:52.667] [I] [zway] Job 0x13 (SensorMultilevel V5 Get): Delivered
[2015-12-18 09:59:52.667] [D] [zway] SETDATA devices.5.data.lastPacketInfo.delivered = True
[2015-12-18 09:59:52.667] [D] [zway] SETDATA devices.5.data.lastPacketInfo.packetLength = 7 (0x00000007)
[2015-12-18 09:59:52.667] [D] [zway] SETDATA devices.5.data.lastPacketInfo.deliveryTime = 14 (0x0000000e)
[2015-12-18 09:59:52.667] [D] [zway] SETDATA devices.5.data.lastPacketInfo = **********
[2015-12-18 09:59:52.668] [D] [zway] SendData Response with callback 0xe0 received: received by recipient
[2015-12-18 09:59:52.668] [D] [zway] SETDATA devices.5.data.lastSend = 2945544 (0x002cf208)
[2015-12-18 09:59:52.668] [D] [zway] Job 0x13 (SensorMultilevel V5 Get): success
[2015-12-18 09:59:52.668] [I] [zway] Removing job: SensorMultilevel V5 Get
[2015-12-18 09:59:52.737] [D] [zway] SENDING (cb 0xe1): ( 01 0B 00 13 05 04 31 04 1B 00 05 E1 2C )
[2015-12-18 09:59:52.739] [D] [zway] RECEIVED ACK
[2015-12-18 09:59:52.742] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-12-18 09:59:52.743] [D] [zway] SENT ACK
[2015-12-18 09:59:52.743] [D] [zway] Delivered to Z-Wave stack
[2015-12-18 09:59:52.757] [D] [zway] RECEIVED: ( 01 07 00 13 E1 00 00 02 08 )
[2015-12-18 09:59:52.758] [D] [zway] SENT ACK
[2015-12-18 09:59:52.758] [I] [zway] Job 0x13 (SensorMultilevel V5 Get): Delivered
[2015-12-18 09:59:52.758] [D] [zway] SETDATA devices.5.data.lastPacketInfo.delivered = True
[2015-12-18 09:59:52.758] [D] [zway] SETDATA devices.5.data.lastPacketInfo.packetLength = 7 (0x00000007)
[2015-12-18 09:59:52.758] [D] [zway] SETDATA devices.5.data.lastPacketInfo.deliveryTime = 14 (0x0000000e)
[2015-12-18 09:59:52.758] [D] [zway] SETDATA devices.5.data.lastPacketInfo = **********
[2015-12-18 09:59:52.758] [D] [zway] SendData Response with callback 0xe1 received: received by recipient
[2015-12-18 09:59:52.758] [D] [zway] SETDATA devices.5.data.lastSend = 2945553 (0x002cf211)
[2015-12-18 09:59:52.758] [D] [zway] Job 0x13 (SensorMultilevel V5 Get): success
[2015-12-18 09:59:52.758] [I] [zway] Removing job: SensorMultilevel V5 Get
[2015-12-18 09:59:52.828] [D] [zway] SENDING (cb 0xe2): ( 01 09 00 13 05 02 84 08 05 E2 89 )
[2015-12-18 09:59:52.830] [D] [zway] RECEIVED ACK
[2015-12-18 09:59:52.834] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-12-18 09:59:52.834] [D] [zway] SENT ACK
[2015-12-18 09:59:52.834] [D] [zway] Delivered to Z-Wave stack
[2015-12-18 09:59:52.868] [D] [zway] RECEIVED: ( 01 07 00 13 E2 00 00 03 0A )
[2015-12-18 09:59:52.868] [D] [zway] SENT ACK
[2015-12-18 09:59:52.869] [I] [zway] Job 0x13 (Wakeup Sleep): Delivered
[2015-12-18 09:59:52.869] [D] [zway] SETDATA devices.5.data.lastPacketInfo.delivered = True
[2015-12-18 09:59:52.869] [D] [zway] SETDATA devices.5.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2015-12-18 09:59:52.869] [D] [zway] SETDATA devices.5.data.lastPacketInfo.deliveryTime = 34 (0x00000022)
[2015-12-18 09:59:52.869] [D] [zway] SETDATA devices.5.data.lastPacketInfo = **********
[2015-12-18 09:59:52.869] [D] [zway] SendData Response with callback 0xe2 received: received by recipient
[2015-12-18 09:59:52.869] [D] [zway] SETDATA devices.5.data.lastSend = 2945564 (0x002cf21c)
[2015-12-18 09:59:52.869] [D] [zway] Job 0x13 (Wakeup Sleep): success
[2015-12-18 09:59:52.869] [D] [zway] SETDATA devices.5.data.isAwake = False
[2015-12-18 09:59:52.870] [D] [zway] Sending the queue for node 5 into sleep
[2015-12-18 09:59:52.870] [I] [zway] Removing job: Wakeup Sleep
[2015-12-18 09:59:53.283] [D] [zway] RECEIVED: ( 01 0B 00 04 00 05 05 31 05 05 01 22 E2 )
[2015-12-18 09:59:53.283] [D] [zway] SENT ACK
[2015-12-18 09:59:53.283] [D] [zway] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
[2015-12-18 09:59:53.283] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2015-12-18 09:59:53.283] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2015-12-18 09:59:53.284] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.5.val = 34.000000
[2015-12-18 09:59:53.286] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.5.scaleString = "%"
[2015-12-18 09:59:53.286] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.5 = Empty
[2015-12-18 09:59:58.278] [D] [zway] RECEIVED: ( 01 0B 00 04 00 05 05 31 05 1B 01 00 DE )
[2015-12-18 09:59:58.279] [D] [zway] SENT ACK
[2015-12-18 09:59:58.279] [D] [zway] SETDATA devices.5.data.lastReceived = 0 (0x00000000)
[2015-12-18 09:59:58.279] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.27.deviceScale = 0 (0x00000000)
[2015-12-18 09:59:58.279] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.27.scale = 0 (0x00000000)
[2015-12-18 09:59:58.279] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.27.val = 0.000000
[2015-12-18 09:59:58.281] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.27.scaleString = "UV index"
[2015-12-18 09:59:58.282] [D] [zway] SETDATA devices.5.instances.0.commandClasses.49.data.27 = Empty
[2015-12-18 10:00:00.115] [I] [core] --- ZWayVDev_zway_5-0-48-1 performCommand processing: {"0":"update"}
[2015-12-18 10:00:00.116] [I] [zway] Adding job: SensorBinary Get
[2015-12-18 10:00:00.131] [E] [core] Callback execution error: ReferenceError: debugPring is not defined
at ZDataHolder.<anonymous> (<anonymous>:3:9)
[2015-12-18 10:00:00.146] [I] [core] CHANGED TO: true
[2015-12-18 10:00:02.049] [I] [core] CHANGED TO: trueAny ideas?
