I couldn't find how to set and get some things via JSON API ZAutomation
1) a certain level of the dimmer:
http://192.168.1.10/ZAutomation/api/v1/ ... way_1-0-2/.......... ????
2) get a battery level of the sensor
http://192.168.1.10/ZAutomation/api/v1/ ... _2-0-31-1/
doesn't show battery status ;(
3) get only temperature level - not whole answer:
http://192.168.1.10/ZAutomation/api/v1/ ... _2-0-31-3/
......."metrics":{"probeTitle":"Temperature","scaleTitle":null,"level":8,2"icon":"temperature","title":"Temp"}.......
need JSON commands
Re: need JSON commands
I found 1);
../ZAutomation/api/v1/devices/ZWayVDev_zway_2-0-30/command/exact?level=50
Still couldn't find a solution for questions 2), 3),
another question:
4) ../ZAutomation/api/v1/notifications --> could I get only events of one device or I have to parse it by external tools?
another question:
Have you tried reading and making any sense of the superb documentation (slightly sarcastic) at
http://docs.zwayhomeautomation.apiary.io?
It says
I tried by listing all notifications and then grabbing an id like
but it didn't work for me at least. Maybe you have better success
. Unfortunately it doesn't seem possible to list notifications per device?
Checking the battery section for device:
Doesn't say much to me, but maybe you can decrypt this. Probably you can't get the battery level without doing some additional parsing?
It says
Retrieve a Notification
http://r3bfish.ddns.net:8083/ZAutomation/api/v1/notifications/idCode: Select all
http://localhost:8083/ZAutomation/api/v1/notifications/1454367882Checking the battery section for device:
deviceType Metrics Commands Examples
battery probeTitle,scaleTitle, level, icon, title - -Re: need JSON commands
This documentation is not up to date, and some of the described functions are not (yet?) implemented. On top of that the Apiary people decided to beautify the layout, which imho did not add to its usabilitybogr wrote:Have you tried reading and making any sense of the superb documentation (slightly sarcastic) at
Noooo, that's cheating - he wanted to use the ZAutomation API
Not only cheating, but not fit for the future either. They have written somewhere that the JS interface is going to disappear.bogr wrote:Noooo, that's cheating
v2.1.1 raspi2
Really? That doesn't sound to good if the ZAutomation is the only alternative then?
Mike Yeager
Anyone find a way to read the ZAutomation data using a timestamp to get only the changes since the last read?
http://RAZIP:8083/ZAutomation/api/v1/devices
geeft je alle devices
