Version 2.2.1 is out
islipfd19
Re: Version 2.2.1 is out
Post by islipfd19 » 23 Feb 2016 13:26
ronie wrote:Package name should be the same as class name e.g. 'AeonMultiSensor' (like it already is in HA /modules) and the structure should look like this:
islipfd19 wrote: index.js
module.json
lang\de.json
lang\en.json
lang\ru.json
Thanks! But I'm pretty sure it is. I fail to see why it won't upload.
pz1
Post by pz1 » 23 Feb 2016 14:07
islipfd19 wrote:Thanks! But I'm pretty sure it is. I fail to see why it won't upload.
The ZIP in your earlier post isn't correct, the directory level AeonMultiSensor should not be there:
islipfd19
Post by islipfd19 » 24 Feb 2016 13:52
The attachment Capture.PNG is no longer available
I've tried uploading the attached one as well and it failed.
AeonMultiSensor.tar.gz
(44.34 KiB) Downloaded 188 times
ronie
Post by ronie » 24 Feb 2016 17:40
Jup upload fails. There seems to be an error during upload that is not handled correctly.
We'll check this. And we'll check the format of your package too.
ronie
Post by ronie » 25 Feb 2016 10:11
Seems that .tar.gz isn't the same as .tar.gz ...
I've packed your package with the programm 7-Zip (first made a .tar and then a .gz from .tar)
And tried to upload it - works without problems.
As you can see also the size is a bit different ...
So how did you pack your module? With an othe programm?
(43.72 KiB) Downloaded 215 times
islipfd19
Post by islipfd19 » 26 Feb 2016 00:37
ronie wrote:Seems that .tar.gz isn't the same as .tar.gz ...
I packed it as tar.gz, not tar and then gz. I'll try that and report back.
islipfd19
Post by islipfd19 » 26 Feb 2016 13:36
I tried your method with 7-zip form a WIndows PC and still no luck; I get an invalid path. I've even attempted using a zip format.
Albeit, my attempts at this have been using both a Windows 7 PC with 7-Zip and Ubuntu 15.10!
pz1
Post by pz1 » 26 Feb 2016 14:45
I did make my package as follows on my Raspberry Pi:
cd /opt/z-way-server/automation/userModules/PVLogger
 sudo tar -cvzf PVLogger.tar.gz *
With WinSCP I did transfer the archive to my win7 PC and uploaded it. (actually a couple of weeks ago)
(I did send that recipe to Marcel K for possible inclusion in the manual)
islipfd19
Post by islipfd19 » 27 Feb 2016 16:37
pz1 wrote:I did make my package as follows on my Raspberry Pi:
That's the difference, I was using the folder to create the packages, tar.gz/zip; which is wrong. The files should be used instead as your command illustrates. I've upload my modules without any issue.
