Webif is switch off
kozaczynski
Re: Webif is switch off
Post by kozaczynski »
has someone figured out how to fix the problems described on this thread?
I took the latest version of Rasbian and I installed z-wave on it. when I connect to port 8083 the server briefly show a dialog and then returns the html text. when I connect to port 8084 I get the message that "Webif is switched off". I get the same result when I start from the image downloaded from the z-wave site.
Srun
Post by Srun »
Managed to purge previous installation of version and installed a new 2.3.0.
Created a new zbox identity and when I first started my_ip:8084 page is worked to set up remote access and closed the browser at my raspberry PI. Reincluded all my devices etc.
After this I got the same problem again. "Webif is switched off ...".
Followed the instruction by bogr;
sudo sh -c "echo 900 > /opt/z-way-server/automation/storage/8084AccessTimeout-6b497208061ec7faae003cdd7f9a035e.json"
It worked again. Thanks but what is the root cause. I would like to avoid this happening again.
Srun
Post by Srun »
After closing the my_ip:8084 browser page, I got the same problem again.
Opening a new browser page at my_ip:8084 resulted in "Webif is switched off ...".
Running the command again;
It worked again.
brosensteiner
Post by brosensteiner »
Actually it is enough to open 8084AccessTimeout....json in an editor, save it (without any modification) and the server is reachable again. 100% repeatable at least with my Razberry.
diegoraspberrypi
Post by diegoraspberrypi »
thanks guys , now raspberry and z wave are working !!!
thanks thanks !!!
this is my case and this is what i did , if it helps u i will be happy !!
1 i did install this noobs with wheezy NOOBS_v1_4_1 , you can find the old .zip files right in the official page. (DONT INSTALL HIGHER VERSIONS THAN NOOBS 1.4.1 )
2 port 8083 wasnt working ... it was only letters ... no html was rendered ...
3 i did install chromioum for raspberry pi and then i was able to see 8083 ... harmony browser its a terrible browser !!
4 i did use sudo sh -c "echo 900 > /opt/z-way-server/automation/storage/8084AccessTimeout-6b497208061ec7faae003cdd7f9a035e.json"
so i was able to activate 8084 and i didnt have to update to a new version.
5 i went to 8083 then i went to expert and i was able to activate my switcher device !!!
thanks everybody !!
