Virtual thermostat maximum temperature.
cyberhofi
Post by cyberhofi » 22 Feb 2016 22:31
is there a reason why the maximum temperature for an virtual thermostat is 40°C?
A chance to set higher temperatures would be great (eg for water heaters). Maybe it wold be good to define the maximum temperature while configuring the app.
redmac68
Re: Virtual thermostat maximum temperature.
Post by redmac68 » 28 Feb 2016 19:36
Same issue here. Is there any way to modify the max temperature allowed by the virtual thermostat application.
The restriction to 40C does not suit all applications (e.g. hot water tank). Any help would be appreciated.
