Login?
Posted: 25 Feb 2016 21:50
Just setting up my RaZberry for the first time.
At first I could not login to the 8084 port it just came up with Webif is switched off. You can switch it on from Z-Way UI or box shell.
I did get logged in to port 8083 and it wanted to do a firmware upgrade to 2.2.1 so I let it do that. Then it was stuck on the upgrade saying it was finished but needed to upgrade again and again. I did get past that know to the login screen to put in my user and password. I enter it and try to login.
It comes up with user not found to check user or password.
Does anyone know what happened?
