Page 1 of 2
razberry scenes
Posted: 22 Mar 2016 16:32
by marko4791
I want to ask you, what is the easiest way for creating scenes. Is there a program to do it ? it works in Expert UI ?or I have to programing using JSON API? I want to create only a simple relation between motion sensor and switche.
Thanks !
Re: razberry scenes
Posted: 22 Mar 2016 17:28
by pz1
Use Expert UI
Menu:Configuration
Tab:Association
Re: razberry scenes
Posted: 22 Mar 2016 17:41
by marko4791
Yes i used, but it didnt work. I have Zipato switch modul and Fibaro motion sensor. I set association between them, but nothing has happened.
Re: razberry scenes
Posted: 22 Mar 2016 19:31
by pz1
Has the interview of both devices been completed?
(Also you can search this forum with the terms: association motion)
Re: razberry scenes
Posted: 01 Apr 2016 10:50
by marko4791
Yes interview is complete. Can you tell me how to set up the correctly associations, it is possible that I am doing them wrong. Or do you know about any manuals?
Re: razberry scenes
Posted: 01 Apr 2016 12:36
by pz1
This image shows how I made the association from a Zwave.me WallC-S controller(ControllerSlkLA) to a binary switch (Vliering). The first association is with the ZWay controller, so it does get signalled by the wall controller. (click image to see full size)
Unfortunately there is virtually no simple user instruction.
Re: razberry scenes
Posted: 01 Apr 2016 12:58
by marko4791
i send images setting association sensor and switch. It is correct ? I dont know, but I want when sensor detects motion turn on the switch.
Re: razberry scenes
Posted: 01 Apr 2016 13:11
by pz1
What you do seems correct to me. But I must admit I have very little knowledge/Experience with associations
Re: razberry scenes
Posted: 01 Apr 2016 13:17
by marko4791
OK, but how I can create a completely smart home by raZberry? scenes and the like. Only through API programming?
Re: razberry scenes
Posted: 01 Apr 2016 13:25
by pz1
I must leave that problem of association to the forum owners. In principle it should work.
I can't answer your question
Since I do not know what you mean by it. What must be made smart?
There are some 50 Apps now for ZWay that can help you make more or less intelligent solutions.
