Can't set MultiChannelAssociation
bogr
Post by bogr »
I'm trying to set MultiChannelAssociation for my Qubino Flush 2 relay according to:
/JS/Run/zway.devices[10].MultiChannelAssociation.Set(3,1,2)
i.e for the Group 3, adding the controller (Raz with id 1), and the instance to include which is 2. I just keep getting null as a result when trying to get the value:
/JS/Run/zway.devices[10].MultiChannelAssociation.Get(3)
When trying to set the value the log looks like
[2016-03-22 22:20:14.291] [I] [zway] Adding job: MultiChannelAssociation Set
[2016-03-22 22:20:14.291] [I] [zway] Adding job: Assign return route
[2016-03-22 22:20:14.291] [I] [zway] Adding job: MultiChannelAssociation Get
[2016-03-22 22:20:14.298] [D] [zway] SENDING (cb 0xfd): ( 01 0D 00 13 0A 06 8E 01 03 00 01 02 25 FD BA )
[2016-03-22 22:20:14.300] [D] [zway] RECEIVED ACK
[2016-03-22 22:20:14.304] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-03-22 22:20:14.304] [D] [zway] SENT ACK
[2016-03-22 22:20:14.304] [D] [zway] Delivered to Z-Wave stack
[2016-03-22 22:20:14.319] [D] [zway] RECEIVED: ( 01 07 00 13 FD 00 00 02 14 )
[2016-03-22 22:20:14.319] [D] [zway] SENT ACK
[2016-03-22 22:20:14.319] [I] [zway] Job 0x13 (MultiChannelAssociation Set): Delivered
[2016-03-22 22:20:14.319] [D] [zway] SETDATA devices.10.data.lastPacketInfo.delivered = True
[2016-03-22 22:20:14.320] [D] [zway] SETDATA devices.10.data.lastPacketInfo.packetLength = 9 (0x00000009)
[2016-03-22 22:20:14.320] [D] [zway] SETDATA devices.10.data.lastPacketInfo.deliveryTime = 15 (0x0000000f)
[2016-03-22 22:20:14.320] [D] [zway] SETDATA devices.10.data.lastPacketInfo = **********
[2016-03-22 22:20:14.320] [D] [zway] SendData Response with callback 0xfd received: received by recipient
[2016-03-22 22:20:14.320] [D] [zway] SETDATA devices.10.data.lastSend = 148607445 (0x08db91d5)
[2016-03-22 22:20:14.320] [D] [zway] Job 0x13 (MultiChannelAssociation Set): success
[2016-03-22 22:20:14.320] [I] [zway] Removing job: MultiChannelAssociation Set
[2016-03-22 22:20:14.390] [D] [zway] SENDING (cb 0xfe): ( 01 06 00 46 0A 01 FE 4A )
[2016-03-22 22:20:14.391] [D] [zway] RECEIVED ACK
[2016-03-22 22:20:14.399] [D] [zway] RECEIVED: ( 01 04 01 46 01 BD )
[2016-03-22 22:20:14.399] [D] [zway] SENT ACK
[2016-03-22 22:20:14.399] [D] [zway] Delivered to Z-Wave stack: process started
[2016-03-22 22:20:14.741] [D] [zway] RECEIVED: ( 01 05 00 46 FE 00 42 )
[2016-03-22 22:20:14.741] [D] [zway] SENT ACK
[2016-03-22 22:20:14.741] [D] [zway] AssignReturnRoute Response with callback 0xfe received: received by recipient
[2016-03-22 22:20:14.741] [D] [zway] Job 0x46 (Assign return route): success
[2016-03-22 22:20:14.741] [I] [zway] Removing job: Assign return route
[2016-03-22 22:20:14.742] [D] [zway] SENDING (cb 0x01): ( 01 0A 00 13 0A 03 8E 02 03 25 01 44 )
[2016-03-22 22:20:14.746] [D] [zway] RECEIVED ACK
[2016-03-22 22:20:14.748] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-03-22 22:20:14.748] [D] [zway] SENT ACK
[2016-03-22 22:20:14.748] [D] [zway] Delivered to Z-Wave stack
[2016-03-22 22:20:14.767] [D] [zway] RECEIVED: ( 01 07 00 13 01 00 00 02 E8 )
[2016-03-22 22:20:14.767] [D] [zway] SENT ACK
[2016-03-22 22:20:14.767] [I] [zway] Job 0x13 (MultiChannelAssociation Get): Delivered
[2016-03-22 22:20:14.767] [D] [zway] SETDATA devices.10.data.lastPacketInfo.delivered = True
[2016-03-22 22:20:14.767] [D] [zway] SETDATA devices.10.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2016-03-22 22:20:14.767] [D] [zway] SETDATA devices.10.data.lastPacketInfo.deliveryTime = 19 (0x00000013)
[2016-03-22 22:20:14.768] [D] [zway] SETDATA devices.10.data.lastPacketInfo = **********
[2016-03-22 22:20:14.768] [D] [zway] SendData Response with callback 0x01 received: received by recipient
[2016-03-22 22:20:14.768] [D] [zway] SETDATA devices.10.data.lastSend = 148607489 (0x08db9201)
[2016-03-22 22:20:14.768] [D] [zway] Job 0x13 (MultiChannelAssociation Get): success
[2016-03-22 22:20:14.768] [I] [zway] Removing job: MultiChannelAssociation Get
[2016-03-22 22:20:14.776] [D] [zway] RECEIVED: ( 01 0B 00 04 00 0A 05 8E 03 03 10 00 61 )
[2016-03-22 22:20:14.777] [D] [zway] SENT ACK
[2016-03-22 22:20:14.777] [D] [zway] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2016-03-22 22:20:14.777] [I] [zway] Node 10:0 CC MultiChannelAssociation: Group 3 report
[2016-03-22 22:20:14.777] [D] [zway] SETDATA devices.10.instances.0.commandClasses.142.data.3.max = 16 (0x00000010)
[2016-03-22 22:20:14.777] [D] [zway] SETDATA devices.10.instances.0.commandClasses.133.data.3.nodes = byte[0]
[2016-03-22 22:20:14.777] [D] [zway]   ( zero-length buffer )
[2016-03-22 22:20:14.777] [D] [zway] SETDATA devices.10.instances.0.commandClasses.142.data.3.nodesInstances = byte[0]
[2016-03-22 22:20:14.777] [D] [zway] SETDATA devices.10.instances.0.commandClasses.133.data.3.nodesToFollow = **********
[2016-03-22 22:20:14.778] [D] [zway] SETDATA devices.10.instances.0.commandClasses.142.data.3.nodesInstancesToFollow = **********
[2016-03-22 22:20:14.778] [D] [zway] SETDATA devices.10.instances.0.commandClasses.142.data.3 = Empty
and getting the value:
[2016-03-22 22:20:32.868] [I] [zway] Adding job: MultiChannelAssociation Get
[2016-03-22 22:20:32.874] [D] [zway] SENDING (cb 0x02): ( 01 0A 00 13 0A 03 8E 02 03 25 02 47 )
[2016-03-22 22:20:32.876] [D] [zway] RECEIVED ACK
[2016-03-22 22:20:32.880] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-03-22 22:20:32.881] [D] [zway] SENT ACK
[2016-03-22 22:20:32.881] [D] [zway] Delivered to Z-Wave stack
[2016-03-22 22:20:32.895] [D] [zway] RECEIVED: ( 01 07 00 13 02 00 00 02 EB )
[2016-03-22 22:20:32.896] [D] [zway] SENT ACK
[2016-03-22 22:20:32.897] [I] [zway] Job 0x13 (MultiChannelAssociation Get): Delivered
[2016-03-22 22:20:32.897] [D] [zway] SETDATA devices.10.data.lastPacketInfo.delivered = True
[2016-03-22 22:20:32.898] [D] [zway] SETDATA devices.10.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2016-03-22 22:20:32.898] [D] [zway] SETDATA devices.10.data.lastPacketInfo.deliveryTime = 15 (0x0000000f)
[2016-03-22 22:20:32.899] [D] [zway] SETDATA devices.10.data.lastPacketInfo = **********
[2016-03-22 22:20:32.899] [D] [zway] SendData Response with callback 0x02 received: received by recipient
[2016-03-22 22:20:32.900] [D] [zway] SETDATA devices.10.data.lastSend = 148609267 (0x08db98f3)
[2016-03-22 22:20:32.900] [D] [zway] Job 0x13 (MultiChannelAssociation Get): success
[2016-03-22 22:20:32.901] [I] [zway] Removing job: MultiChannelAssociation Get
[2016-03-22 22:20:32.906] [D] [zway] RECEIVED: ( 01 0B 00 04 00 0A 05 8E 03 03 10 00 61 )
[2016-03-22 22:20:32.906] [D] [zway] SENT ACK
[2016-03-22 22:20:32.907] [D] [zway] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2016-03-22 22:20:32.907] [I] [zway] Node 10:0 CC MultiChannelAssociation: Group 3 report
[2016-03-22 22:20:32.908] [D] [zway] SETDATA devices.10.instances.0.commandClasses.142.data.3.max = 16 (0x00000010)
[2016-03-22 22:20:32.908] [D] [zway] SETDATA devices.10.instances.0.commandClasses.133.data.3.nodes = byte[0]
[2016-03-22 22:20:32.909] [D] [zway]   ( zero-length buffer )
[2016-03-22 22:20:32.909] [D] [zway] SETDATA devices.10.instances.0.commandClasses.142.data.3.nodesInstances = byte[0]
[2016-03-22 22:20:32.910] [D] [zway] SETDATA devices.10.instances.0.commandClasses.133.data.3.nodesToFollow = **********
[2016-03-22 22:20:32.910] [D] [zway] SETDATA devices.10.instances.0.commandClasses.142.data.3.nodesInstancesToFollow = **********
[2016-03-22 22:20:32.911] [D] [zway] SETDATA devices.10.instances.0.commandClasses.142.data.3 = Empty
any ideas, anyone?
Re: Can't set MultiChannelAssociation
Looks like device's bug... Report to Qubino instead.
