http://razberry.z-wave.me/index.php?id=29
This is the last part of my log file:
[2016-04-02 02:49:15.740] [D] [zway] Opened device: /dev/ttyAMA0
[2016-04-02 02:49:15.741] [D] [zway] Worker thread successfully created
[2016-04-02 02:49:15.741] [D] [zway] Worker thread entry point
[2016-04-02 02:49:15.742] [I] [zway] Adding job: Get controller info and supported function classes
[2016-04-02 02:49:15.751] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2016-04-02 02:49:15.953] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2016-04-02 02:49:15.953] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2016-04-02 02:49:16.155] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2016-04-02 02:49:16.155] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2016-04-02 02:49:16.357] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2016-04-02 02:49:16.357] [W] [zway] Job 0x07 (Get controller info and supported function classes) dropped: too many resends
[2016-04-02 02:49:16.357] [D] [zway] Job 0x07 (Get controller info and supported function classes): fail
[2016-04-02 02:49:16.357] [C] [zway] Get Serial API Capabilities returned zero.
[2016-04-02 02:49:16.357] [I] [zway] Removing job: Get controller info and supported function classes
[2016-04-02 02:49:16.368] [D] [zway] Worker thread exit point
[2016-04-02 02:49:16.368] [D] [zway] Worker thread successfully finished
[2016-04-02 02:49:16.369] [E] [zway] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
[2016-04-02 02:49:16.400] [I] [core] Notification: critical (z-wave): Cannot start Z-Wave binding: Error: Bad data - communication failed
I am unable to get into the expert UI because of an error:
"Error handling data from server"
The card is correctly installed on pins 1-10.
Its a new Z-wave card and I have tried it on a raspberry pi 1 and a raspberry pi 2.
I have tried it on the pre built image from Z-wave me and also the install script on a clean install of Raspian.
Raspian is up to date.
Any ideas on what to try next or is there a way to reset the Z-wave card in the terminal?
