Razberry Z wave board on Noobs 1.9
Bruttern
Post by Bruttern »
Hey.
(Long time listener, first time caller)
I've been using the z wave board on a raspberry pi 2 using the image downloaded from z-wave website:
http://razberry.z-wave.me/index.php?id=24 / http://razberry.z-wave.me/z-way-server/razberry.img.zip.
The board is able to communicate to all my devices and have been operating ok for a couple of months. However, the image is based an older version of weezie/jessie, and for some reason it does not work properly with xrdp/tightvnc.
Recently I updated my Raspberry clean with a Noobs 1.9 from https://www.raspberrypi.org/downloads/noobs/. Now I have more updated features on the Raspberry (wifi/remote desktop/pyton programming upgrades), but after installing the z-wave software (wget -q -O - razberry.z-wave.me/install | sudo bash), the raspberry is having communication problems with the z-wave board.
I've followed all steps on http://razberry.z-wave.me/index.php?id=29 - but no luck.
I think this might be similar to the treads https://forum.z-wave.me/viewtopic.php?f=3422&t=21834 and https://forum.z-wave.me/viewtopic.php?f=3422&t=23095
The errors after installation and upgrades are presented in the come us in the UI as "Error handling data from server" and "Cannot start Z-wave binding: Error: Bad data - communication failed".
Just for kicks I reinstalled the Raspberry with the original image from http://razberry.z-wave.me/z-way-server/razberry.img.zip - again the z-wave board communicates fine with the raspberry, but again the xrdp or tightvnc does not work properly.
Are there any know issues with Noobs 1.9 running on the Rasp communicating with the z-wave board?
:geek:
DomotikQuebec
Re: Razberry Z wave board on Noobs 1.9
Post by DomotikQuebec »
Can you log in the UI and verify the config of the Z-Wave Network access app ?
(Apps -> Active -> Z-Wave Network access)
I had to change it manually to /dev/ttyAMA0 once... I don't remember when or why but I remember having to fix it after some kind of update.
Mario Gravel
Domotik Quebec
Bruttern
Post by Bruttern »
I just checked, the Z-wave network access app Serial port to Z-Wave dongle: /dev/ttyAMA0
sploff
Post by sploff »
Check your boot\cmdlint.txt i got same problem with no comunication with z-wave board after a reistallation.
i had to edit \boot\cmdline.txt and took away "console=serial0,115200 "
My original cmdline.txt
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Bruttern
Post by Bruttern »
sploff - you rock!
It did the trick! Thanks a million!
sploff
Post by sploff »
Nice :D
Waugh369
Post by Waugh369 »
So apparently I do have a problem with the board. I have the 2 leds on all the time. they are on, but in a low brightness. maybe you have the same issue?
could you paste your cmdline.txt content? (/boot/cmdline.txt)
