OTA firmware update?
Hi. Can you confirm that the OTA firmware update of devices work in the latest 2.2.1 and 2.2.2 versions? I have tried to update a device providing a manufacturer provided hex file and using target 0. From the log it seems like update runs, but after completion I see no changes to the application version running on the device I just tried to update. Any pointers? Thank you.
Re: OTA firmware update?
You need to convert hex to bin first. In future we plan to add internal hex->bin converter, but this is in our TODO.
Make sure to find a converter able to deal with BANKs!
Digging old threads
What is this about exactly?
Could you explain a bit?
I have an .ota file, apparently containing hexadecimal indeed... where do I go from there?
In new Z-Way you can perfectly use .bin, .hex and .ota just as they are.
