I have a Razberry with the latest version running and all I'd like to do is have a roller shutter shut at a certain time and open at another time. I have this product (https://www.google.de/url?sa=t&rct=j&q= ... 5492,d.bGs) and I've installed it and itÄs working without problem. I can use it with manual switches and I can also use it with the Razberry ZWave Software.
The only thing that I can't get to work is the schedule function. I set up a schedule, set up the right time, activated a dimmer and chose the right item. I set the value right (99 / 0, tried it both ways) but simply nothing ist happening. The device doesn't show any sign of recieving a signal (no LED flashing). Also if I'm setting up a scene where the shutter is moving and add that to the schedule, it doesn't do anything, but if I manually start the scene everything works just fine.
Btw: Cron is active.
Any ideas about why it's not working?
Thanks in advance.
