New Installation on Pi3 using v2.2.2 and AEOTEC Z-Stick Gen5
aupton
Post by aupton »
:?: Hi, first post here. I read through the forums and haven't found a solution so I'm hoping that someone else knows a solution ?
I'm trying to get the Pi3 running Rasbian 4.4.4. Jessi Lite using Razberry 2.2.2 and the Z-Stick Gen5 to work together without much success. I can see that the z-stick is identified by the Kernel at boot as "ttyACM0" and there is a valid device under the /dev filesystem as "/dev/ttyACM0"
However after configuring the "Z-Wave Network Access" app under settings to use /dev/ttyACM0 I'm getting these errors in the log:
"Cannot start Z-Wave binding: Error: Bad data - communication failed"
I've disabled the Bluetooth device via /boot/config.txt as some have suggested as a work around, but this did not work. I've tried rolling back to previous releases, all without success.
However, checking lsmod I see that there are zero devices using the cdc_acm module/driver:
Module Size Used by
cdc_acm 17370 0
This is strange since the cdc_acm driver is reporting this device data to the kernel at boot:
[ 5.466419] cdc_acm 1-1.5:1.0: ttyACM0: USB ACM device
[ 5.467884] usbcore: registered new interface driver cdc_acm
[ 5.467901] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
So I'm a bit stumped. Not sure where to go from here.
Any help would be greatly appreciated. Thank you.
aupton
Re: New Installation on Pi3 using v2.2.2 and AEOTEC Z-Stick
Post by aupton »
Friendly Bump. Still trying to make some progress with this. Is there something obvious that I'm doing wrong or perhaps my expectation to use the USB z-stick is off?
Under Zwave Network Access it asks to configure these parameters:
Settings:
You need to set the IP address of the Remote Box including the port number.
You need to define the polling interval. Once second in a quite good choice.
You need to manage the remove device to be included into you UI.
I'm confused as to why it requires the IP of a remote box when I'm not using a remote box... I'm simply trying to get the z-wave stick to initialize on the Pi so I can control some pre-existing z-wave light switches that are currently under Home Seer's control.
What am I missing here ?
Thanks!
