External request after mouvement detection
Posted: 05 May 2016 12:59
by Slayes
I bought raspberry, razberry and fibaro sensor motion.
Somebody could tell me, how it's possible (with the more simple method) to send a external http request when the IR of the Fibaro has detected a mouvement ?
I'm sorry for my poor english, a sample will be more clear :
- When my Fibaro detected a mouvement
- Raspberry send this request :
http://www.xxxx.fr/entry.php?source=[ad ... sensorName]
I have a little knowledge in php, js, python.
Thanks by advance for your help.
Re: External request after mouvement detection
Posted: 06 May 2016 15:12
by Slayes
I tried this code, found on this post :
https://forum.z-wave.me/viewtopic.php?f=3422&t=20028
At the end of file main.js
var zone = 'www.xxxx.fr/zwave/action.php?';
var port = 80;
zway.devices[11].instances[0].commandClasses.SensorBinary.data[1].level.bind(function() {
eventString = 'Device_11_Instance_0';
try {
system(
"python /opt/z-way-server/automation/script/network_send.py",
eventString,
this.value,
zone,
port
return;
} catch(err) {
debugPrint("Failed to execute script system call: " + err);
#!/usr/bin/python2.7
import sys
import subprocess
zone = str(sys.argv[3])
port = int(sys.argv[4])
eventString = str(sys.argv[1])
payloadString = ''
print "Message de test"
sys.stdout.flush()
try:
payloadString = str(sys.argv[2])
except:
pass
try:
url = zone + "&source=" + eventString + "&value=" + payloadString
subprocess.call(["wget", "-O/dev/null", url])
sys.exit(0)
except:
sys.exit(0)
I did the test with a Everspring SM103, i can see that in the log :
[2016-05-06 12:07:24.233] [D] [zway] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
[2016-05-06 12:07:24.233] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcNodeId = 11 (0x0000000b)
[2016-05-06 12:07:24.233] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcInstanceId = 0 (0x00000000)
[2016-05-06 12:07:24.233] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.level = 0 (0x00000000)
[2016-05-06 12:07:24.234] [D] [zway] SETDATA devices.11.instances.0.commandClasses.48.data.1.level = False
[2016-05-06 12:07:24.234] [D] [zway] SETDATA devices.11.instances.0.commandClasses.48.data.1 = Empty
[2016-05-06 12:07:24.250] [I] [core] Notification: device-info (device-OnOff): {"dev":"Everspring General purpose (11.0.48.1)","l":"off"}
But my script is never called, somebody can help me plz ?
Posted: 06 May 2016 19:59
by bogr
Sounds like it might be easier to just use the "HTTP Device" app and configure your URL for "URL for action ON" and then just create a "Logical Rule" with the condition "Fibaro sensor movement" in "Type of condition" and in section "Actions" you just chose "List of switches" = the newly created "HTTP device" and chose "On"?
Posted: 07 May 2016 10:20
by Slayes
Thanks for your reply.
I tried this solution in first time, but i need to add more dynamic parameters in the request. I prefer try to use python for this task.
Posted: 07 May 2016 11:14
by Slayes
I corrected one line :
by
zway.devices[11].instances[0].commandClasses[48].data[1].level.bind(function() {
console.log('Point 1');
Now i can see on the log that the code is executed.
But the next command see below is not executed :
system(
"/usr/bin/python /opt/z-way-server/automation/script/network_send.py",
I added these lines on the file .syscommands
Somebody know where is my fault plz ?
Posted: 07 May 2016 11:58
by bogr
Ok, I understand you point about the need for more dynamic handling.
I guess that you have entered the values in .syscommands on each line like:
/usr/bin/python
I haven't messed around with python (just bash), but it looks like your python script has defined version 2.7, but in your syscommands you entered python? In my RPi I see that python links to python2.7, so maybe you have to add 2.7 as well to syscommands? Just grasping here
. Otherwise you could just try to replace the python script with a bash containing only an "echo test" just for testing and debugging and verifying that the system call part actually works. In that case the problem has to be python related.
Posted: 08 May 2016 09:53
by Slayes
I don't understand, certainly i did an error but i don't see it.
In the end of the file '/opt/z-way-server/automation/main.js'
var zone = 'www.xxx.fr/zwave/action.php?id_test=de&ede=defrfr';
var port = 80;
try {
console.log('Point 2');
system("sh /opt/z-way-server/automation/script/test.sh");
return;
} catch(err) {
My /opt/z-way-server/automation/.syscommands file :
sh
End my script : /opt/z-way-server/automation/script/test.sh
#!/bin/bash
echo Mon premier script
I start the z-way-server with :
sudo cp /dev/null /var/log/z-way-server.log && sudo /etc/init.d/z-way-server restart && tail -f /var/log/z-way-server.log
When i action my Everspring SM103, i can see in the log :
[D] [zway] RECEIVED: ( 01 09 00 04 00 0B 03 20 01 63 B8 )
[D] [zway] SENT ACK
[D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.level = 99 (0x00000063)
[D] [zway] SETDATA devices.11.instances.0.commandClasses.48.data.1.level = True
[core] Point 1
[core] Point 2
[core] Notification: device-info (device-OnOff): {"dev":"Everspring General purpose (11.0.48.1)","l":"on"}
I didn't see "Mon premier script" from my bash script.
Posted: 08 May 2016 16:18
by bogr
Don't know if it's of any difference, but when I call a script I just do:
system("/opt/z-way-server/automation/script/test.sh");
and I don't put "sh" in .syscommands, but my looks like:
echo
Don't know if the echo goes to the log-file, but I would just redirect it to a file like:
#!/bin/bash
echo "Mon premier script" > /tmp/test.txt
Posted: 09 May 2016 08:48
by Slayes
It was my fault, in my sh or python script i used 'echo' or 'print' to trace the execution of the script. And i monitored the file '/var/log/z-way-server.log'. It was a problem of linux knowledge.
Thanks everybody for your help.
