Problem with Select Device Description (v2.2.2-test)
Posted: 26 May 2016 12:52
by thomas.hicks
I'm running v2.2.2-test-new-webserver on Raspbian GNU/Linux 8 (jessie).
I have 3 Popp Smoke Detectors (004001) that I included in my Z-wave Network.
However I cannot configure these detectors ("No device description selected"). When I try to Select Device Description in the interview tab I can select "Popp & Co. Popp Smoke Detector" as first option in the dropdown. It does not show an image and when I click on select I get the following Error :
"Error handling data
/ZWave.zway/Run/devices[6].LoadXMLFile("undefined")"
Another problem seems to be that after updating to v2.2.2 I get "Error handling data from server" in the Timing Info, Controller info and other screens. I also get a blank text box when trying to reorganise the network.
Problems seem to be related to the following threads :
https://forum.z-wave.me/viewtopic.php?f=3422&t=21884
https://forum.z-wave.me/viewtopic.php?f=3422&t=21769
but the solutions mentioned there don't help. :?:
Re: Problem with Select Device Description
Posted: 26 May 2016 15:21
by noctoz
I have the same problem on this version for both my aeon multisensor and fibaro wall plug.
Posted: 28 May 2016 13:40
by CrazyFin
I am on Windows version v2.2.2-test-new-webserver-5-gba57763 and experience the same problem.
I can not select any device description without getting error message
/ZWave.zway/Run/devices[7].LoadXMLFile("641-0159-0003-0002-03-03-1c-01-0c.xml")"
I get similar error message for all devices I am trying.
Re: Problem with Select Device Description (v2.2.2-test)
Posted: 02 Jun 2016 18:05
This is a know problem, we have made a fix and will publish it tomorrow.
Menawhile you can use v2.2.2.
Stay updated: https://github.com/Z-Wave-Me/z-way-issues/issues/107
Posted: 03 Jun 2016 02:56
New v2.2.2-test-new-webserver-8-ga9cd319 should fix the problem
