New localhost user needs password
Wikibear
Post by Wikibear »
Hello together,
i have an issue with a local user. I deleted the local host user, cause i don't get in touch from command line with api without login. Then i wanted to create a new local host user... yes i do but only with login. If i want to set this user without passwort the form will denied any further assist... How can i create now a local user without login?
I using v2.2.2-rc3.
PS: The Api denied access with error 401 authorisation required from command line.
Thanks.
Greatings from the noob
Wikibear
Re: New localhost user needs password
Post by Wikibear »
Nobody any idea?
local user will work only if you access from the same host, means from 127.0.0.1 to 127.0.0.1
To use API you still need to get session cookie.
