Connection refused by the z-way-server
rasserie
Post by rasserie »
Hello
Within LAN, I am able to login and no disconnection from the server.
However, remotely, I get intermittent error messages as attached.
It works for the first couple of seconds where I can navigate the pages as per normal and then the error comes up.
Any ideas?
Cheers
sir_ray
Re: Connection refused by the z-way-server
Post by sir_ray »
I have the exact same problem. I rebooted my raspberry but that didn't help. Did you get it solved, if so how did you do it?
dti
Post by dti »
Hey,
I've got the same error message since a few days. Lan and remote access. How did you solve this problem?
In my opinion the connection is fine, so I think the real problem is another one.
Best greetings
dti
dti
Post by dti »
Problem solved.
I've deleted the notification file, cause it has been to big. After that the system runs very fast again
jacksun101
Post by jacksun101 »
I just got the same message when I was trying to setup RaZberry on the new Raspbian Stretch. @dti, where is the notification file?
jacksun101
jacksun101 wrote:
30 Aug 2017 12:59
OK, I know what's going on. It's because I use the latest Raspbian Stretch, it's too new which is somehow incompatible with z-way-server. So, please use Jessie instead.
HeHa
Post by HeHa »
I'm experiencing the same now with 2.3.8. Highly unstable.
I have performed format and fresh install from image, followed by firmware update, twice:
http://razberry.z-wave.me/z-way-server/razberry.img.zip
Where to start debugging?
HeHa
Post by HeHa »
downgrade to 2.3.7 and it seems to run without issues.
