Reorganization is unavailable?
phzi
Post by phzi »
I can't seem to find any information about this in any of the manuals I've found about the razberry and Z-way -
The "Network>Reorganization" option in the Z-Way Expert UI is greyed out, and manually navigating to the URL just bounces back to the homepage as is reorganization doesn't exist.
I'm using an RPI3 w/ razberry running latest firmware.
How can I access this functionality?
I have a GE in-wall outlet that I can't get connecting well to the networ, even thought there are definitely nodes it could talk to. I could manually design the routing table better then what the controller has created so far. Unplugging the main controller for 15+min didn't help routing much either.
phzi
Re: Reorganization is unavailable?
Post by phzi »
Any ideas? The timing section lists devices but no packets (all say 0% okay, despite all nodes communicating just fine).
Has been answered before.
Both timing and reorganisation functions are under serious reconstruction at the moment. If I understood things correctly we will get much better insight in system functioning. I don't kow if it is in the next release, which is expected towards the end of this month
phzi
Post by phzi »
Okay, thank-you, pz1. I swear I looked around for quite a while and searched these forums too.
It's not easy to find info about this product beyond the manuals (which are fairly good at least, albeit outdated).
phzi wrote:Okay, thank-you, pz1. I swear I looked around for quite a while and searched these forums too.
It indeed is a pain to find info on the forum and other places. Maybe I just read in a Github issue
