Dears,
this morning I've updated a raspberry from v2.2.3 to v2.2.5.
_____________________________________________________________________________________________________
pi@raspberrypi ~ $ wget -q -O - razberry.z-wave.me/install/v2.2.5 | sudo bash
Installing additional libraries
Get:1 http://archive.raspberrypi.org jessie InRelease [13.2 kB]
Get:2 http://mirrordirector.raspbian.org jessie InRelease [14.9 kB]
Get:3 http://archive.raspberrypi.org jessie/main Sources [48.6 kB]
Get:4 http://mirrordirector.raspbian.org jessie/main armhf Packages [8,982 kB]
Get:5 http://archive.raspberrypi.org jessie/ui Sources [15.2 kB]
Get:6 http://archive.raspberrypi.org jessie/main armhf Packages [117 kB]
Get:7 http://archive.raspberrypi.org jessie/ui armhf Packages [53.6 kB]
Ign http://archive.raspberrypi.org jessie/main Translation-en_GB
Ign http://archive.raspberrypi.org jessie/ui Translation-en_GB
Get:8 http://mirrordirector.raspbian.org jessie/contrib armhf Packages [37.5 kB]
Get:9 http://mirrordirector.raspbian.org jessie/non-free armhf Packages [70.3 kB]
Get:10 http://mirrordirector.raspbian.org jessie/rpi armhf Packages [1,356 B]
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/main Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en_GB
Fetched 9,354 kB in 44s (209 kB/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
gawk is already the newest version.
sharutils is already the newest version.
The following packages will be upgraded:
libc-ares2 tzdata
2 upgraded, 0 newly installed, 0 to remove and 145 not upgraded.
Need to get 252 kB of archives.
After this operation, 5,120 B of additional disk space will be used.
Get:1 http://mirrordirector.raspbian.org/raspbian/ jessie/main libc-ares2 armhf 1.10.0-2+deb8u1 [66.6 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian/ jessie/main tzdata all 2016f-0+deb8u1 [185 kB]
Fetched 252 kB in 0s (263 kB/s)
Preconfiguring packages ...
(Reading database ... 35879 files and directories currently installed.)
Preparing to unpack .../libc-ares2_1.10.0-2+deb8u1_armhf.deb ...
Unpacking libc-ares2:armhf (1.10.0-2+deb8u1) over (1.10.0-2) ...
Preparing to unpack .../tzdata_2016f-0+deb8u1_all.deb ...
Unpacking tzdata (2016f-0+deb8u1) over (2016d-0+deb8u1) ...
Setting up tzdata (2016f-0+deb8u1) ...
Current default time zone: 'Europe/Rome'
Local time is now: Thu Nov 24 08:41:44 CET 2016.
Universal Time is now: Thu Nov 24 07:41:44 UTC 2016.
Run 'dpkg-reconfigure tzdata' if you wish to change it.
Setting up libc-ares2:armhf (1.10.0-2+deb8u1) ...
Processing triggers for libc-bin (2.19-18+deb8u1) ...
Installing additional libraries for HomeKit
libavahi-compat-libdnssd-dev is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 145 not upgraded.
Installing libarchive-dev
Building dependency tree...
The following extra packages will be installed:
libarchive13
Suggested packages:
lrzip
libarchive-dev libarchive13
2 upgraded, 0 newly installed, 0 to remove and 143 not upgraded.
Need to get 624 kB of archives.
After this operation, 1,024 B of additional disk space will be used.
Get:1 http://mirrordirector.raspbian.org/raspbian/ jessie/main libarchive-dev armhf 3.1.2-11+deb8u3 [393 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian/ jessie/main libarchive13 armhf 3.1.2-11+deb8u3 [231 kB]
Fetched 624 kB in 1s (465 kB/s)
Preparing to unpack .../libarchive-dev_3.1.2-11+deb8u3_armhf.deb ...
Unpacking libarchive-dev:armhf (3.1.2-11+deb8u3) over (3.1.2-11+deb8u2) ...
Preparing to unpack .../libarchive13_3.1.2-11+deb8u3_armhf.deb ...
Unpacking libarchive13:armhf (3.1.2-11+deb8u3) over (3.1.2-11+deb8u2) ...
Processing triggers for man-db (2.7.0.2-5) ...
Setting up libarchive13:armhf (3.1.2-11+deb8u3) ...
Setting up libarchive-dev:armhf (3.1.2-11+deb8u3) ...
Getting Z-Way for Raspberry Pi and installing
--2016-11-24 08:42:34-- http://razberry.z-wave.me/z-way-server/ ... v2.2.5.tgz
Resolving razberry.z-wave.me (razberry.z-wave.me)... 46.20.244.36
Connecting to razberry.z-wave.me (razberry.z-wave.me)|46.20.244.36|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 26367873 (25M) [application/x-gzip]
Saving to: â/tmp/z-way-server-RaspberryPiXTools-v2.2.5.tgzâ
/tmp/z-way-server-RaspberryPiXTools-v2.2.5.tgz 100%[======================================================================================================>] 25.15M 766KB/s in 33s
2016-11-24 08:43:07 (788 KB/s) - â/tmp/z-way-server-RaspberryPiXTools-v2.2.5.tgzâ saved [26367873/26367873]
Extracting new z-way-server
Previous z-way-server installation found
Stopping z-way-server: done.
Making backup of previous version of Z-Way in /opt/z-way-server_2016-11-24-08-43-12
Copying settings
cp: cannot stat â/opt/z-way-server_2016-11-24-08-43-12/config/Rules.xmlâ: No such file or directory
!!! Defaults.xml and config.xml updated with new versions !!!
Creating Z-Way startup script
Adding z-way-server to autostart
Getting Webif for Raspberry Pi and installing
--2016-11-24 08:43:46-- http://razberry.z-wave.me/webif_raspberry.tar.gz
Length: 412185 (403K) [application/x-gzip]
Saving to: âSTDOUTâ
- 100%[======================================================================================================>] 402.52K 661KB/s in 0.6s
2016-11-24 08:43:46 (661 KB/s) - written to stdout [412185/412185]
[ ok ] Stopping zbw_connect (via systemctl): zbw_connect.service.
zbw_connect patched
[ ok ] Starting zbw_connect (via systemctl): zbw_connect.service.
Getting webserver mongoose for Webif
--2016-11-24 08:43:48-- http://razberry.z-wave.me/mongoose.pkg.rPi.tgz
Length: 44749 (44K) [application/x-gzip]
Saving to: â/tmp/mongoose.pkg.rPi.tgzâ
/tmp/mongoose.pkg.rPi.tgz 100%[======================================================================================================>] 43.70K --.-KB/s in 0.1s
2016-11-24 08:43:48 (338 KB/s) - â/tmp/mongoose.pkg.rPi.tgzâ saved [44749/44749]
Stopping mongoose http server
[ ok ] Stopping mongoose (via systemctl): mongoose.service.
Adding mongoose to autostart
Start mongoose http server
[ ok ] Starting mongoose (via systemctl): mongoose.service.
Opened config/zddx/f23e6d6b-DevicesData.xml
Starting z-way-server
Starting z-way-server: done.
Thank you for using RaZberry!
Almost everything (except "cp: cannot stat â/opt/z-way-server_2016-11-24-08-43-12/config/Rules.xmlâ: No such file or directory") seems went ok.
Once update was finished I done routine checks. With my surprise in the management section reported frimware version is still v2.2.3! Same in the expert UI. But weird thing is that even if I stop server via ssh it still continue working!
Anyone have an idea on this?
v2.2.5 issue
Re: v2.2.5 issue
Did you reboot your Raspberry Pi? Worked for me in a similar situation half a year ago with a different set of versions
Re: v2.2.5 issue
I tried to reinstall new version again. Non error reported but nothig changed.
After a raspberry reboot it seems work now but webif is not reachable anymore.
Marco
