Dears,
I'm running zway server v2.2.5 on a Raspberry Pi 2. I've stated that after a server reboot all multibuttons disappear from the UI. Then it need to recall all them from Active App page and save them again to be sure they will return in the UI.
Does anybody know how to fix this issue?
MULTI BUTTON ISSUE
Re: MULTI BUTTON ISSUE
I don't have any fix, but can confirm this behavior.
Customer support suggestion was to reinstall the App.
This morning I’ve deleted all multibuttons, uninstalled Multi Button App definitely from the system.
Then I’ve reinstalled App again and I’ve programmed only 3 Multibuttons in their relevant rooms.
Once the system was rebooted, the problem was still present.
All Multibuttons were disappeared and there was need of recalling them one by one and save their configuration again to make them visible again in the UI.
Marco
Support (Support)
15. Dez., 08:48 CET
Hello Marco,
thanks for the report. I have forwarded this to the development team of the app, they added this error to the bug list. They will fix that as soon as possible.
15. Dez., 08:48 CET
Hello Marco,
Marco
Support (Support)
1. Aug., 11:40 CEST
Hallo Marco,
thank's for your report.
Your enquiry was forwarded to the developement team. They'll try to plan it for the next sprints.
You will see a red up arrow button on the local app widget if an update is available.
Best regards
Z-Wave Europe Support
1. Aug., 11:40 CEST
Hallo Marco,
Best regards
Marco
