How to execute API commands via HTTP API?
golaonline
Post by golaonline »
All,
Anyone knows or has done it. I know it can be done as per the sample given inside the network, but how do you execute such commands via outside access via find.z-wave.me?
Sample I am aware of is curl -v -u admin:admin 192.168.0.62:8083/ZAutomation/api/v1/devices/ZWayVDev_zway_6-0-37/command/on
from the docs at http://razberry.zwave.me/index.php?id=13
kWave
Re: How to execute API commands via HTTP API?
Post by kWave »
You could open the port 8083 in your Router and direct it to your Controller, but i would not recommend this in terms of security.
golaonline
I am looking at an option that's safe and secure. I do understand that there are some cookies being returned with header 'ZBW-SESSID', but I am trying to see how I can replicate with my own code, I have had no luck getting these returned, when I try to make a call to login via find.z-wave.me. Calling APIs locally with internal IPs works as expected.
Thanks,
Provo
Post by Provo »
This doesn't answer your question completely, but if you go to find.z-wave.me in your web browser, enter your Razberry ID and password, and then log in to your z-way system, the API is available like normal, simply by using the address bar and URLs like https://find.z-wave.me/ZAutomation/api/ ... command/on. So I guess it should work if you do this remote id login process with Curl and save the cookies to preserve the session id and everything needed for the service to know to which Razberry it should connect. If find.z-wave.me doesn't support passing on basic auth, you would have to do the login process with Curl and save the cookies for this as well. There is an example here, which you might be able to modify for your needs: http://razberry.z-wave.me/index.php?id=13
Sparkacus
Post by Sparkacus »
I too am looking for a solution that would allow a 3rd party to communicate with a z-way controller via the Z-WAY API, without having to touch router configurations.
I've designed an app that will work with virtual assistants such as Alexa, but the only way my app will work at the moment is for a user to store their Z-WAY username/pass on my app, open up their router to allow access from my server before this will work, which for obvious reasons is not good - https://forum.z-wave.me/viewtopic.php?f=3419&t=24642
Even if I could get this to work with the find.z-wave.me service, I'd still need to store user credentials.
I could look into developing a client web socket module for Z-WAY, which then authenticates with my app and relays commands which then would allow the user to store the Z-WAY user credentials locally, but this is complicated and I'd rather not look into it if there are already plans in place for a more secure remote service to interact with 3rd party apps.
I don't suppose the administrators could offer some advice please?
I don't really get what you want. You want to use find.z-wave.me remote access but don't want to store user credentials? How do you want to authenticate then? Using a token?
ZBW-SESSID is the token you need. You can pass it via cookie or via header - does not matter. This is to pass find.z-wave.me.
Also you need Z-Way token to auth on Z-Way itself. This one can also come via header or cookie
But both are temporarily sessions. Making them permanent is pretty same as to store user name and password
