Can't get into any UI
Posted: 21 Dec 2016 21:51
by SparkyRih
I'm trying to get the RazBerry board to work on a Pi3B, but I can't access port 8083 (page can't be displayed), on port 8084 I get the "Webif is switched off. You can switch it on from Z-Way UI or box shell" error.
Also, I notced on the desktop that Bluetooth is not working (no adapters available), but I guess that's to avoid the RX/TX from conflicting?
Any help?
Edit: When I checked the z-way-server file in /etc/init.d/ I found that the path pointed to /opt/z-way-server, my folder there was named z-way-server_2016-12-21-16-55-34... So I renamted it and manually started, now I can at least access the 8083 website... So I guess from there I should be able to get more stuff working...
Re: Can't get into any UI
Posted: 22 Dec 2016 17:53
by enbemokel
The /opt/z-way-server seems to be the working directory while z-way-server_date_time are backups if you
installed a new version.
Posted: 22 Dec 2016 18:48
by SparkyRih
I did reinstall/upgrade (using the same command as to install), but that didn't seem to change anything... When I checked the opt folder today, there was no "z-way-server", only the one with the date, by renaming that it worked... With your explanation, I find it even more strange, but well, it works
Port 8083 works fine, but 8084 doesn't, but I apparently don't need it? (at least for now)
Now I'm trying to include a device (Everspring HSM02-1), the LED on the Razberry goes on when I put it in inclusion mode via the Expert UI, but it doesn't seem to find the device (I did read the manual on how to put it in inclusion mode)...
Posted: 23 Dec 2016 12:18
by pz1
SparkyRih wrote:only the one with the date, by renaming that it worked... With your explanation, I find it even more strange, but well, it works.
After a complete crash, this renaming is a perfect way to resurrect an older working version.
Posted: 23 Dec 2016 15:49
by SparkyRih
pz1 wrote:SparkyRih wrote:only the one with the date, by renaming that it worked... With your explanation, I find it even more strange, but well, it works.
But I never had a working version
so theoretically it shouldn't have worked... But like I said it works
Also the inclusion of the magnet switch, it probably is due to the switch itself, I just picked up a couple of Z-Uno's, and the first one I tried included perfectly fine...
