Hello forum,
Happy New Year!
I'm hoping this forum can answer some newbie questions on how best I can build my automation setup. In my case I'm looking to monitor some sensors (water detection and battery charger) for our boats in our boathouse. I have a Raspberry Pi 3 and would like to use it as our sensor hub. I'm hoping this community can see if my setup plan will work or not. Here is what I'm planning to do:
Use z-wave wireless sensors.
Use a Raspberry Pi 3 and RaZberry addon on to connect to the sensors.
Our boathouse has wifi internet so I'll be able to connect the Raspberry Pi 3 to the Internet.
Install OpenHAB on my home server.
Install OpenVPN on my Raspberry Pi.
Collect the data from the z-wave sensors and send this data in real time to my OpenHAB server.
My earlier investigation on this setup is to use MQTT (maybe a python script) to send this data to my OpenHAB server over VPN.
Does this setup sound like it will work? If not, where are the holes that need to be corrected?
Further questions for this setup:
Is there a way to keep my Raspberry Pi O/S from becoming corrupted? I'd love to be able to have my O/S in read only mode so no corruption can occur. Is this possible when collecting data and sending it to OpenHAB?
Any advice or pointers you can provide would be greatly appreciated.
Thank you.
Help me with questions in building my z-wave using RaZberry
Re: Help me with questions in building my z-wave using RaZbe
I've been digging deeper into sensors using z-wave so perhaps I'll add more detail to this forum post in hopes that someone from this community can point me in the right direction.
I'm still looking to monitor sensors from our cottage. And I still want to run OpenHAB on my home server (which is not at the cottage). So specific question for this forum:
How can I use a Raspberry Pi with a RaZberry addon board attached to collect data from my cottage sensors and push this data over the Internet (via VPN) to my home server running OpenHAB? What do I need to build on my Raspberry Pi to do this?
Any help or direction you can provide me would be greatly appreciated.
Thank you.
Thank you.
If no one has ever setup what I would like to use for my setup then even knowing that information will help me understand what I can and maybe can't do! Any advice this community can give me would be greatly appreciated.
Thank you.
Thank you.
