Cannot start Z-Wave binding: Error: Bad data - communication
Posted: 04 Jan 2017 00:34
Tried both on Raspberry Pi 2 and 3. I always get this error:
(on pi 3 I'm using the latest Pixel os version)
I checked the 'Known Problems' section:
1. the led is blinking for a second on boot.
2. I removed console=serial0,115200 from my cmdline.txt (I still have console=tty1 in there).
Here is my cmdline.txt:
Here is the end of my config.txt:
3. I checked on the "Z-Wave Network Access" app that "Serial port to Z-Wave dongle" is set on "/dev/ttyAMA0".
4. I also tried to change it to "/dev/serial0", "/dev/serial1" and "/dev/ttyS0". all with the same result.
5. also checked that I placed the board on the far right side of the pin array, like shown in the site.
Nothing helps. I understand this is the most common problem with RaZberry. is there anything I can do??
Please help, being troubleshooting this for the last 3 days, emailing the "Support - Z-Wave Europe GmbH" but there answers are not helping.
Thanks.
[2017-01-03 23:26:03.977] [D] [zway] Opened device: /dev/ttyAMA0
[2017-01-03 23:26:03.977] [D] [zway] Worker thread successfully created
[2017-01-03 23:26:03.977] [D] [zway] Worker thread entry point
[2017-01-03 23:26:03.977] [I] [zway] Adding job: Get controller info and supported function classes
[2017-01-03 23:26:03.987] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2017-01-03 23:26:04.190] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2017-01-03 23:26:04.191] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2017-01-03 23:26:04.394] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2017-01-03 23:26:04.395] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2017-01-03 23:26:04.598] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2017-01-03 23:26:04.598] [W] [zway] Job 0x07 (Get controller info and supported function classes) dropped: too many resends
[2017-01-03 23:26:04.598] [D] [zway] Job 0x07 (Get controller info and supported function classes): fail
[2017-01-03 23:26:04.598] [C] [zway] Get Serial API Capabilities returned zero.
[2017-01-03 23:26:04.598] [I] [zway] Removing job: Get controller info and supported function classes
[2017-01-03 23:26:04.608] [D] [zway] Worker thread exit point
[2017-01-03 23:26:04.609] [D] [zway] Worker thread successfully finished
[2017-01-03 23:26:04.610] [E] [zway] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
[2017-01-03 23:26:04.631] [I] [core] Notification: critical (z-wave): Cannot start Z-Wave binding: Error: Bad data - communication failed1. the led is blinking for a second on boot.
dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p7 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwaitCode: Select all
# NOOBS Auto-generated Settings:
hdmi_force_hotplug=1
config_hdmi_boost=4
overscan_left=24
overscan_right=24
overscan_top=16
overscan_bottom=16
disable_overscan=0
gpu_mem=160
dtoverlay=pi3-disable-bt
enable_uart=14. I also tried to change it to "/dev/serial0", "/dev/serial1" and "/dev/ttyS0". all with the same result.
Thanks.
