Pi3+Razberry
djekspek
Pi3+Razberry
Post by djekspek »
Hi all, trying to get this working for some time now. Disabled BT, followed many instrcutions on the web, etc. As I understand I can use razberry on /dev/ttyAMA0 with openzwave now. Everything 'seems' to be working (in openzwave control panel from domoticz all looks ok; debuggni shows no errorc etc.) but no devices/nodes (except the controller) are found when trying to add nodes. So I'm thinking the module itself is not working... (I checked LED's etc. as stated in known issues and all looks ok as well). Is there any way I can check some log, or do a test on commandline, to see if the razberry device is working properly on ttyAMA0 ? Cannot find anything on the web... Thanks!
djekspek
Re: Pi3+Razberry
Post by djekspek »
this can be closed; found out the zwave dimmer was broken...
