Zway Exclusion works - Inclusion not
Posted: 29 Apr 2017 12:01
Hi there! I am new to the Raspberry/Razberry/Z-Wave world and it's driving me nuts
I use a Raspberry PI 3 B with Razberry2 ZMEERAZ2 and installed Z-Way on Raspian. In Z-Way I want to add a Fibaro Roller Shutter 2 FGR-222 (EU). I start the exclusion and push the B-Button on the Fibaro 3 times very fast and Z-Way shows me a success message. After that I start the inclusion and hit the B-Button 3 times very fast again but the inclusion runs in a timeout ('inclusion takes a long time to start up').
I did a factory reset on the Fibaro and tried a second Fibaro Roller Shutter 2 but it ended up with the same behaviour.
Then I installed Z-Way again (this time I used the SD-card image) and again: The exclusion works but the inclusion not.
Is it likely that I have a bad Razberry-Module and a replacement unit should work?
Thanks for any suggestion before I have to send the device back!
