Now unable to remote log in
Posted: 05 May 2017 20:07
by Phil80
Ive been successfully able to log in at work via my iPhone through the find.z-wave site.
Now after i had to power down the raspberry i can not log in remotely using the website, if i do i receive this error --Remote access not possible or wrong password
If i try this on my laptop (remote site) same issue. If i log in locally through the browser port 8083 I can access it - I copy and past my user + pw so i know its correct but does not work remote.
In the way server settings nothing has changed, remote management/access is still selected.
I tried deleting browser, cache but still no luck.
Re: Now unable to remote log in
Posted: 05 May 2017 23:30
by janjan
Hi Phil80,
did your Raspi get a New ip from your Router After the shotdown? Perhaps its the reason for it.
Good luck
Posted: 05 May 2017 23:48
by Phil80
Hi JanJan,
On the Pi i assigned it a static ip for the wifi (not using ethernet) i then also signed static ip in the router to the mac address of the wifi dongle.
Maybe i should only assign in one place??
Phil
Posted: 06 May 2017 00:05
by Phil80
@JanJan
I removed the static ip assigning in the wifi settings using the GUI of Jessie and just left the router assigning. rebooted and it works!
Great news ( just can't understand why it stopped even though i told it to use same number)
Thanks for querying it so i tried.
