Hi all, im new on this forum
I have tried to find a solution for my problem but couldnt.
Can anyone help me with this?
Im trying to add this thermostat but i cant get 100% interview, only 88%, the command i get refuse is ThermostatSetPoint and Association
I found over internet that on other platforms like openhub and home-assistant they already found the solution by making it own template with ThermostatSetMultiPoint or something similar, but even if i now have access to those templates, i dont know where to put them and more importart, how to set my device to use it.
RaZberry + GC-TBZ48
Re: RaZberry + GC-TBZ48
Bump on this post; same basic problem.
I've obtained xml files from the alliance library and from the open z-wave library, but I can't get UpdateXMLs.sh to add them to the index even after some minor tweaks. The result is always a "list index out of range" error.
Are there any translators (either scripted or a written manual) to convert these xml files to something that will be processed by UpdateXMLs.sh?
I know I'm posting to a nearly 3 year old forum post and normally I wouldn't, but I was just given two of these thermostats as a gift while I remodel my house.
I've hooked up one and I can never get the interview to complete.
The devices are powered using the 24VAC common and so should not be going to sleep.
The interview reaches about 86%, failing to complete the ThermostatSetPoint, AssociationGroupInformation, and Association components.
Were you ever able to get this thermostat to complete its interview successfully?
